2022 running headlight DRL out at 48k miles.
Old Oct 27, 2025 | 10:26 AM
GavinC's Avatar
Originally Posted by matthewjlove
thank you!
if I go the easy route and pick up one off eBay is there any reprogramming needed?
No. Plug and play.
Old Oct 28, 2025 | 12:24 AM
jwest's Avatar
Seems like JLR should be replacing every one of these gratis -- or for cost of labor only -- for Defender owners and sending the bill straight back to the supplier / headlamp manufacturer who should be bending over backwards to retain JLR’s business.
Yet they are not doing this. Puzzling really.
It’s not JLR’s fault. It’s the supplier’s fault. But how they are handling it -- is JLR’s fault.
And it reflects poorly on the brand to see at least 25% of Defenders driving around town with one of the DRL’s burned out. Which is definitely the case right now in Portland OR.
(mine died with 28500 miles on mine. right outside the 4 year warranty. denied. unhappy. im just running it without the DRL)
I just went to see a 2021 and neither of them would come on. But neither would either fog lamp even though the fog lamp dash icon comes on. I'm getting a pre-purchase inspection done tomorrow by a LR dealer so we shall see what's up with that. 65,000 miles on it.
Old Oct 28, 2025 | 12:28 AM
jwest's Avatar
Originally Posted by GavinC
I replaced one for $380
simple diy basic tools 30 minutes. Hour max.
I repaired another for $3
trickier but doable.
get yourself a light on eBay. There are countless OEM lights on eBay. I got one with a barely detectable scratch. It’s effectively mint condition. Breakers yards are great. Lucky8 sells a pair for $1400 I think.
these Defenders get totaled very easily. Second hand lights are plentiful. The DRL module if you want to repair are even cheaper. Single figure dollar cost.
just google the lights on eBay. Swap is so versatile simple. Not cheap at $400 ish but not 4 figures.
This is great info. I will now hope the inspection finds the DRL on both lamps are not working so I can use it as a $6000 bargaining chip for price reduction. Then fix them myself like you mentioned.
Old Oct 29, 2025 | 07:03 AM
skw's Avatar
skw
'22 w/ 36k mi and I had the passenger side one go out. 2 months out of warranty and the dealer replaced it. Don't know if their own goodwill or JLR involvement, I didn't ask. When it was done, he showed me to my car, handshake, and I was on my way w/ no paperwork. He did say they had a hard time w/ the programming, but again, I didn't stick around to ask any questions.
My back up plan was the junkyard or Ebay route, easy to replace the entire headlamp. Powerful UK has an excellent video and the circuit board is only 45 euros on their site but it also says they're not shipping to the US right now.
Old Oct 30, 2025 | 12:49 PM
Iceman153's Avatar
So the halo in these headlights can actually be repaired, the LED that burns out and needs replaced, but it is located inside the headlight. Matt armstrong just did a rebuild video on a defender that had one of the halo's out, and he showed how to remove the lens, replace the bad LED, and put it back together. Looks pretty simple honestly, but it looks like he just used normal body sealant to put it back together, ideally you'd use headlight butyl sealant instead. Looks like you can get what you need on amazon for about $100, assuming you own an oven :P He gets into it at around 14:30, for some reason the forums youtube control doesn't respect the time paramter on the URL :
2020Defender
May 1, 2026 07:40 AM
sayvillerx
Nov 14, 2024 10:03 AM
thebk
Apr 16, 2024 08:49 AM
cmilton
Sep 4, 2022 11:24 AM
snugg
Dec 16, 2008 10:03 PM
