Brake problems need help
Old Mar 10, 2024 | 02:32 PM
Iceman153's Avatar
Originally Posted by Jaredfurubotten
when i buy the iidtool is there anything else i need to purchase with it to be able to flash the codes?
for this specific code I don't think you actually need IIDTool to clear them. Literally just holding the brake pedal down until calibration completes should do it. but if you want to flush the brake fluid completely you'd need it to put the system into service mode.
Old Mar 10, 2024 | 04:42 PM
Jaredfurubotten's Avatar
for me it says its a permanent code. I will try flushing the brake lines and then recalibrating like your post says but for me just holding the brake pedal down once the clicking and stops the warnings are still there
Old Mar 10, 2024 | 08:14 PM
Iceman153's Avatar
it'll take one or two drives for them to clear on their own after calibration is complete
Old Mar 10, 2024 | 08:23 PM
okay so bleed the brake lines and then calibrate and drive around a bit?
Old Mar 11, 2024 | 08:26 AM
mmbanf's Avatar
hi, as Iceman said, you have to bleed the brakes and then try the automatic calibration.
however, if you let the oil and piston escape from the rear calipers, it could be a more serious situation, a lot of air in the system,
As mentioned, phase 1, putting the ABS ECU into service, (Gap or Pathfinder), you must put the system under pressure, (Bosch recommends 2 bar for this system), after having followed the bleeding in the correct sequence, since you have done out the rear piston, you may also need to bleed the rear brake epb, this is what the Pathfinder tool is for.
marco
Old Sep 9, 2024 | 06:47 AM
Pudge0319's Avatar
I changed the rear brakes on my 22 defender 90. Forgot to put in service mode on the first caliper so when i took it off the piston went all the way out and leaked some fluid but brake fluid is still full in the reservoir.
anyways now when i turn on the car it says stability control not available. Auto braking/lane assistance not available and the check engine light is on and so is a red brake light. Any ideas on what might be wrong or how to fix.
ERROR CODE : C055e
how did you resolve your issue? Same exact thing happened to me.
Old Sep 9, 2024 | 12:20 PM
Iceman153's Avatar
Did you try what I suggested fixed my problem a few replies above here? The defender goes into calibration mode for the BBW system when a leak is detected, you pretty much just have to hold the pedal down hard for a minute for it to re-calibrate.
Old Sep 9, 2024 | 02:51 PM
Pudge0319's Avatar
yeah man thanks it finally worked. The problem that I was having was that I didn’t wait until the car fully went to sleep before performing the procedures in the bulletin
JaySun
Mar 10, 2014 03:51 PM
hhalimi
Jan 21, 2012 10:13 AM
BIG
Feb 8, 2010 11:46 AM
skatelove303
May 27, 2009 08:06 AM
LRDISCO
Dec 17, 2007 11:53 AM
