Cargo 110v AC Domestic Outlet - non-functional
Old 11-04-2023 | 08:19 AM
Ratledge's Avatar
Curiously, my MY23.5 D90S has the "domestic outlet" (offroad kit) and no cigarette type outlet.
  #22
Old 11-21-2023 | 10:32 AM
rakusak's Avatar
Originally Posted by drcoop
After nearly 10 months of ownership I've never tried this outlet but today plugged in my solar battery to test for an upcoming trip. No current coming out of the outlet!
Obviously the engine was running as I figured it had to be for this to work. There must be an inverter somewhere inside the vehicle that powers this. The cigarette lighter on the opposite side underneath the integrated air compressor is working fine and all other electrics seem fine. Taking off the rear cargo space fuse box panel and looking through the documentation I can't find any mention of a fuse or breaker to reset.
Anyone run into this problem and have a fix?
Any chance you can provide part number if you can see any from the flap or if its easy enough to access from the inside?
  #23
Old 11-21-2023 | 11:35 PM
bunny's Avatar
7th Gear
@rakusak I've attached an image of the parts book. As you can see, the socket itself is seperate from the cover and the screw.
Here are the parts numbers, categorised by region:
- EU 230V: LR099092
- US 110V: LR099093
- UK 230V: LR099096
- China 230V: LR099095
From looking up the UK part number, I believe this is the same part that's also used on the Range Rover Sport.
I haven't figured out wiring yet. Hopefully someone else is able to help! Best case scenario, it's fits the same port as the cigarette lighter.
Attached Thumbnails Cargo 110v AC Domestic Outlet - non-functional-screenshot-2023-11-22-04.30.32.png
rakusak (11-27-2023)
  #24
Old 11-22-2023 | 03:31 AM
Defendit..'s Avatar
Originally Posted by rakusak
Anyone know how to retrofit this? I have a 2020 P400 with Offroad pack but no domestic outlet in rear... the driver side has the cigarette port but passenger side is sans domestic outlet.
Probably easier to retrofit an capable pure sinus inverter ?
See my mod / upgrade
https://landroverforums.com/forum/20...socket-116827/
  #25
Old 01-27-2024 | 01:33 PM
bunny's Avatar
7th Gear
Yeah after talking to my dealer, he told me that attempting to retrofit this would void my warranty. And tbh voiding a warranty for a single 180w socket isn't worth it. So I'm thinking like you, to put an EcoFlow/Jackery/Bluetti power station under the boot floor space, where there's usually just a ton of styrofoam. However I have a defender 130 with 3 rows, and I'm not sure how to remove/lift up my third row to access the empty void space under the third row.
  #26
Old 01-30-2024 | 10:26 AM
rakusak's Avatar
Not sure how this would void the entire warranty... perhaps if something went wrong with a relate electrical system, but if your front suspension gave way due to a faulty part, it should still be covered.
ficklma1 (02-01-2024)
  #27
Old 03-08-2024 | 08:17 PM
BOBO99's Avatar
Should be plug and play if all the wiring is in the loom. Plug and play would not void anything, I working on adding it OEM. I need to signup for Topix and get the wiring diagram. Dealer should be able to add it no problem, the air compressor can be added.
  #28
Old 03-09-2024 | 11:16 AM
WTFChuck's Avatar
Can’t do a whole lot with 1.6 amps of power. Better off spending the money on a 3,000 ft extension cord.
  #29
Old 03-09-2024 | 07:23 PM
BOBO99's Avatar
I have a camara batter 110v charge i use for work. It's nice to have the domestic JIC I forget to change the battery.
Hensel
10-02-2021 10:33 PM
Magnumforc
05-22-2021 04:58 PM
saravs
12-08-2020 01:19 PM
abran
05-03-2017 02:21 AM
