Dash cam?
Old Mar 10, 2024 | 10:34 PM
Groucho123's Avatar
Default Dash cam?
Anyone found a mount to use on the rearview mirror?
I had one in my 19 RR and it worked great, even was able to feed power up so no wires show.
Thanks.
Old Jun 3, 2024 | 07:26 AM
Groucho123's Avatar
Anyone?
Old Jul 8, 2025 | 05:37 AM
Dinanywor's Avatar
6th Gear
I had the same wiring issue and ended up using a constant power source from the rear fuse box—it worked way better for parking mode. If you're still deciding on a camera, this article helped me pick mine: https://www.technology.org/2025/05/2...amera-in-2025/ . I found something that fits nicely behind the rearview mirror and doesn’t block the sensors.
Old Jul 8, 2025 | 08:27 AM
abran's Avatar
Try these guys:
https://fitcamx.com/search?q=2023+la...r&_ss=e&_v=1.0
Old Jul 8, 2025 | 08:51 AM
DallasDave's Avatar
I recently installed the camera unit (front and rear) from Fitcamx and thinks it's a fantastic solution. The front camera took about 5-10 minutes to install...that's it. They provide the correct wiring to tap into the available connectors, so powering the unit was very, very easy. Initially I didn't like the fact that there is no LCD display, but after a short acclimation I like it better than the Vanture solution in my Audi. You simply connect to the camera with your mobile device. All the recordings and settings are accessed from your mobile telephone. If there is a recording of interest, boom it's already on your mobile device! With my Vantrue/Audi, I have to remove the SD card and download it on my PC.
Plus the Fitcamx isn't terribly expensive!
Here's a link you may find useful: Land Rover Forums
Mike_F
Jun 4, 2025 07:21 AM
hl6
Dec 30, 2023 06:47 PM
ShiftingPangaea
Dec 5, 2023 01:56 PM
FLwolverine
May 11, 2022 02:21 PM
RR2Dfndr
Dec 6, 2021 09:56 PM
