Drivers side headlight washer leaking
Old Aug 13, 2023 | 11:09 AM
brandx's Avatar
Originally Posted by chpsk8
My 23.5 delivered 7 days ago has the same issue. Walked by last night and wondered why there was white stuff all around the drivers headlight washer. I've never used the windscreen washers, haven't had a need so this is just sitting there leaking like that.
The washers activate at startup I think and or when the main windscreen washers are activated. Regardless, mine were also leaking without any prompting of the main windscreen washer and only stopped leaking when the reservoir was 100% empty. I understand the liquid is sent to the nozzle under pressure so if the seal is even slightly compromised it leaks.
I’d recommend getting a call into your service asap. I don’t trust what that liquid could do with extended exposure to the paint. Like I said, took 8 weeks for the parts to be delivered!
good luck.
Old Nov 27, 2023 | 06:04 PM
estecoca's Avatar
3rd Gear
Just picked up a 2024 Defender and the left side headlamp jet is leaking...and making me angry.
I'm going to try the following (in order):
1. Run the washers continuously (hoping there is an obstruction or something else that self resolves)
2. empty the washer fluid tank
Anyone know how to do #2? I popped the hood and the only idea I came up with is sticking a small tube down the chute and siphoning it out...surely there's a better way (please).
Old Nov 27, 2023 | 06:37 PM
Myron's Avatar
Well, good luck and let us know if you discover a secret fix. I asked my dealer and they said, essentially, that every Defender they've delivered since MY2020 had this problem, and that there might be recall/fix coming but no promises.
Personally, it used to bug the **** out of me, but not anymore. I just think of it as my Defender weeping because it misses me when we are apart. Welcome to the club.
Myron
Old Nov 28, 2023 | 07:03 AM
mmbanf's Avatar
Hi everyone, there is a technical bulletin on leakage from headlight washers, the procedure involves a diagnosis with Pathfinder Jlr, however replacement of the part is recommended (sorry for the text in Italian, but I took a photo from my Topix)
Marco
Old Nov 28, 2023 | 07:51 AM
estecoca's Avatar
3rd Gear
Marco
THANK YOU!
The PDF (in English) = MC-10243700-0001.pdf (nhtsa.gov)
Sean Winter
Aug 12, 2022 09:02 AM
Racer X
Oct 24, 2014 06:27 PM
Fallstaff
Jan 5, 2013 03:15 PM
Xrover
Dec 14, 2012 01:26 PM
Street Wolf
Oct 3, 2008 08:40 AM
