GAP IID Tool Summary
Old Jun 1, 2024 | 03:37 AM
  #271
Pangea123's Avatar
Is there a way to disable automatic speed-based suspension height changes? For example, can u disable the logic that makes the truck lower to standard height at 50MPH?
Old Jun 1, 2024 | 06:09 AM
  #272
Defendit..'s Avatar
Llams Height adjuster...
Old Jun 1, 2024 | 07:35 AM
  #273
BD1's Avatar
BD1
With walk away locking enabled is there a way to disable the horn from sounding if you walkway with the door open?
Old Jun 1, 2024 | 10:53 PM
  #274
ThunderBob's Avatar
I need suggestions/assistance with activating Park Assist in my 23.5 Defender 90 P300. I made the following changes with my GAP IID gen 4 device (with latest firmware)
Park assist settings
Activate Park Assist
EUCD-059 Parking Assistance
Standard: Without Parking Assistance
Change to: PDC (Front, Rear) - Parking (Parallel, Exit)
EUCD-099 Park Assist Camera
Standard: Without Park Assist Camera
Change to: With Park Assist Camera
EUCD-140 Pdcautoactivationmenu
Standard: Not supported
Change to: With PDC Auto Activation menu
MultiCAN-469 PDCAutoActivation
Standard: Not Supported
Change to: Default OFF configurable
MultiCAN-500 PDCBtnFCIM
Change to: Fitted
MultiCAN-602 PDC
Standard: PDC not fitted
Change to: 10 Channel fitted ( Park Assist)
MultiCAN-786 Park Assist
Standard: Not Fitted
Change to: Full Auto VarD (Fully automated park assist with automated steering breaking acceleration and gears)
I have the parking going as far as ‘start’ it would find spaces and I can select them but start is greyed out. I’ve reset Pivi multiple times and have let the car sit overnight. Any suggestions on what to attempt next?
Thanks.
Old Jun 2, 2024 | 06:20 AM
  #275
Ratledge's Avatar
Unfortunately that's where most of us get, and mine is an almost identical vehicle (P300 90S MY23.5). Luck of this draw. A very few have it working.
Old Jun 2, 2024 | 07:28 AM
  #276
ThunderBob's Avatar
Thanks for the confirmation. Looks like I’ll be restoring it back to the original settings.
Old Jun 2, 2024 | 12:45 PM
  #277
pjeski's Avatar
My configurable terrain response activation took too full days to work right. Please consider not restoring it right away and see if the same thing happens.
Old Jun 2, 2024 | 09:24 PM
  #278
Ratledge's Avatar
It doesn't hurt just leaving it. Park Assist looks for spots, and I wouldn't likely ever use it. Still, easy to pop up the screen and your dashboard will point left & right when you are driving under 18mph.
Old Jun 4, 2024 | 09:00 AM
  #279
starbai's Avatar
Just curious, has anyone figured out away for the DRLs to not dim with the headlights/fog lights on?
I like the look of the foglights switched on without the full headlights turned on. But then it dims the DRLs which kinda sucks. No biggie, just wondered if anyone has figured it out?
Separately, I like the feature that allows the turn signals in the front to remain illuminated to replace the DRLs. But it seems like one or the other, is there anyway to do both?
Old Jun 4, 2024 | 04:42 PM
  #280
Defendit..'s Avatar
Turning on the headlights and Dim the DRL's saved me from failure of those....
