GAP IID Tool Summary
Old Aug 23, 2025 | 07:37 AM
  #511
H1Tad's Avatar
So just as a point of clarification - for some reason that seems to be a mystery, the 2022 P400's can't turn on the *** memory? it simply won't work on my truck
Old Aug 23, 2025 | 01:44 PM
  #512
Parkstr8's Avatar
I guess on 2025's - the helmet is now on the main Pivi screen in the apps. Versus an icon on the left stacked part.
Found it by accident. When you press it the 4 options then show up.
Old Aug 23, 2025 | 03:27 PM
  #513
Skyfall's Avatar
Originally Posted by PetarJ
Hi Guys ,
I have upgraded my headlights from the standard version to Matix . I had followed the instructions provided on GAP Q&A section :
Menu–Car Config–Complete List;
  • MultiCAN-636 AdaptDrvBeam set to AdaptDrvBeam Enabled
  • MultiCAN-679 HeadlightsVariant set to Headlamp_Variant_High_A ( in my case it is " _C " as it is NAS Defender , but it was tested with _A just n case)
  • MultiCAN-674 AFS123 set to AFS123 Enabled
The second version suggested in another forum was :
CCF Node Current Value Change To
MultiCAN-679 HeadlightsVariant Headlamp_Variant_Mid_C Variant_high_A/B/C (based on region)
MultiCAN-636 AdaptDrvBeam Disabled Enabled
MultiCAN-706 Dyn Bending Light Not fitted Fitted
MultiCAN-693 ADB Initialisation Not fitted Fitted
But the ADB option is not available in the Menu - Exterior Lights - Adaptive Driving Beam, but in my CCF report I can see
  • EUCD-014 Headlights, Type
    Matrix LED AFS123/IHB
I've had done the PIVI reset. Please let me know if you an idea how to do it . Thanks !
Any progress on this? Did pivi resets and complete locked shut downs help to show the option?
what part number headlights did you go with? Where did you source them?
I’m very interested in doing this also, in the US.
Old Aug 23, 2025 | 04:46 PM
  #514
PetarJ's Avatar
I am still playing with the GAP tool. The PIVI reset has been done number of times , No luck yet. Check this out it might be helpful as I have seen your post where premium/ matrix was discussed.
https://docs.google.com/spreadsheets..._Gy8-J/pubhtml
These are mine LR144293 and LR144290. I got them from Allegro, Poland
I suspect that I have to upgrade my BCM in order to let the ADB appear or to
code the lights to the VIN.
Old Aug 29, 2025 | 05:19 PM
  #515
PetarJ's Avatar
I did it finally. I will post the complete list that has to be modified soon. The Matrix lights are a must have upgrade. Special thanks for @Patrick and the GAP team.
Old Aug 29, 2025 | 09:16 PM
  #516
Skyfall's Avatar
That is awesome, congrats! Definitely post that info when you have time, I want to do the same to mine.
Old Aug 31, 2025 | 03:34 PM
  #517
bring44's Avatar
3rd Gear
Doesn't work on my 2020 either. Everything else that I've tried has worked though...Dynamic, ACC, and FOB tailgate opening. I did get Park Assist to show up, but I get nothing once I'm in the screen/mode; just a steering wheel icon.
Old Sep 1, 2025 | 12:18 PM
  #518
PetarJ's Avatar
​​​​Here is the list of changes that I had done to enable Matrix Headlights in my car. Everything is working as expected. In the menu - exterior lights - HD Adaptive Driving Beam toggle has appeared. Functioning as expected. I suspect not all of them are needed and I will update the list once it is verified.
  • EUCD-014 Headlights, TypeMatrix LED AFS123/IHB
  • EUCD-015 Headlights, SymmetryNot supported
  • EUCD-016 Dayrunning LightStandard Dipped Light for Vehicles with Dedicated DRL
  • EUCD-017 Dimmed Dipped HeadlightsNot supported
  • MultiCAN-459 MainBeamVoltCtrlDisabled
  • MultiCAN-459 DipBeamVoltCtrlDisabled
  • MultiCAN-459 FrntPosLmpVoltCtrlDisabled
  • MultiCAN-459 DRLVoltCtrlDisabled
  • MultiCAN-460 CornerLmpVoltCtrlDisabled
  • MultiCAN-460 FrntDirIndVoltCtrlDisabled
  • MultiCAN-460 FrntFogVoltCtrlDisabled
  • MultiCAN-460 AuxFrntLmpVoltCtrlDisabled
  • MultiCAN-468 FntDRLTypeIncorporated DRL and Pos
  • MultiCAN-471 MainBeamFdbkMechBCM receives fault data via LIN
  • MultiCAN-471 LowBeamFdbkMechBCM receives fault data via LIN + Tell Tale
  • MultiCAN-482 FntSdMkrDrvMechDriven via BCM
  • MultiCAN-485 HighBeamDrvMechDriven via BCM
  • MultiCAN-485 LowBeamDrvMechDriven via BCM
  • MultiCAN-636 AdaptDrvBeamEnabled
  • MultiCAN-636 Laser High BeamDisabled
  • MultiCAN-674 AFS123Enabled
  • MultiCAN-679 HeadlightsVariantHeadlamp_Variant_High_A ( mine is NAS so A, other regions : B, C)
  • MultiCAN-693 ADB InitialisationFitted
  • MultiCAN-704 Adap Dry Beamseg4 Segments
  • MultiCAN-706 Dyn Bending LightFitted
  • MultiCAN-750 High Beam LightsNot fitted
  • MultiCAN-750 AHB System StatusAHBA Not fitted
  • MultiCAN-814 Laser High Beam MenuIndependent Laser setting
  • MultiCAN-834 HD Adapt Drive BeamNot supported
Old Sep 1, 2025 | 06:45 PM
  #519
TeddyG's Avatar
Matrix light are not DOT approved, IIRC
Old Sep 2, 2025 | 01:39 AM
  #520
pjeski's Avatar
Fascinating.
