GAP IID Tool Summary
Old Aug 3, 2025 | 06:34 AM
  #491
Defendit..'s Avatar
Originally Posted by GavinC
Yes. Normal
no icon in the panel for Auto. It’s blank.
They still didn't cover that one..So sad it's mentioned so often..
Old Aug 3, 2025 | 08:24 PM
  #492
yr4m2pro's Avatar
6th Gear
Default Key Activation
Does anyone know how to activate an additional key on MY25 with G4 tool? The option shown in the manual is not available in the menu as it is in earlier versions.
Old Aug 3, 2025 | 08:39 PM
  #493
isugoo's Avatar
powerfuluk made a video how to add a key in their YouTube. I followed and successfully activated active key (watch).
Old Aug 3, 2025 | 09:14 PM
  #494
Skyfall's Avatar
Really easy, I’ve activated multiple keys and activity bands, just have to remember to put the car in service mode via the app so it will allow activation of new keys.
Old Aug 3, 2025 | 10:48 PM
  #495
yr4m2pro's Avatar
6th Gear
I’ve watched that video. It is pretty straight forward, if the RFA menu was there after the Service and test menu. That’s my issue. I’ve looked under all of the other menu’s and the key related menus aren’t there. It’s under the manuals menu, where it also tells you to utilize the RFA menu which isn’t there.
Old Aug 4, 2025 | 06:23 AM
  #496
Skyfall's Avatar
You will probably need to update the tool to the beta version build 195.
https://www.gap-diagnostic.com/wordp...DToolV4.00.pdf
page 42- update
Old Aug 4, 2025 | 09:56 AM
  #497
yr4m2pro's Avatar
6th Gear
page 42- update
Thanks, I will try that later today.
Old Aug 4, 2025 | 11:27 PM
  #498
yr4m2pro's Avatar
6th Gear
That didn’t work. No way to downgrade the version.
Old Aug 4, 2025 | 11:55 PM
  #499
abran's Avatar
Email GAP directly. They will guide you step by step.
Scan ECU info and send that to them. Small mailbox delivery icon at the bottom of the window.
Old Aug 5, 2025 | 12:51 PM
  #500
nashvegas's Avatar
Yes. Normal
And btw this is how it is from the factory on cars that come equipped with Auto Terrain response. There is no indication in the instrument cluster when you’re in auto. It’s not just a coding issue when you add it to the car.
