GAP IID Tool Summary
OK, I can try that. There’s also “vehicle reset” on the GAP tool, is that worth trying you think? I’ve had to drive the car every day to go to work so I haven’t been able to let it go to sleep mode. In fact I’m not sure it’s ever been in sleep mode, I’ve never noticed that in the JLR app. I do have a noco trickle charger, I’ve been using that.
I also did wire a noco eyelet harness to the jump points under the hood and zip tie it out of the way, I wondered if maybe that somehow affected the ACC system but I can’t imagine how, and the fault codes seem purely software oriented, they don’t describe a blocked or blind sensor or something, it’s all communications/messaging between units in the car.
I did un-do the CCF for the WiFi because that seemed to be what messed up the ACC, and in my queries with AI (which may or may not be accurate) it seemed to think that the WiFi change would involve telematics that could disrupt the ACC. So now the only changes I’ve left are the key fob tailgate release, the splash screen, and the auto start/stop memory. I can’t imagine any of those have anything to do with ACC.
I'm no expert so I can't tell what the vehicle reset on the GAP tool really does. Maybe send an email to them asking. You don't want to brick your ECU modules. Having the battery well charged is a must, these cars have so many sensors everywhere, a drop in voltage can throw codes and many times they cascade. The eyelet should not be an issue as long as they don't short. I also have one I've made for my ctek and I used a thermal protector tubing around those wires, can't have them melt and short while driving as engine bays get really hot. The zipties I used are also high temp rated. As for the wi-fi I really don't know, it starts getting into software code that frankly I don't think anyone is really familiar with.
Patrick from GAP came to the rescue. Apparently changing the splash screen (EUCD-205 Racing Sub Brand) was the culprit. This cannot be changed on model year 2026 and there is no workaround.
He didn’t elaborate as to the cause but I’m guessing this branding is not purely cosmetic and is something that is checked between communicating ECUs in the new model year, and so must remain internally consistent. The faults I saw appear to suggest that an inconsistency broke communication between the DADC and other ECUs leading to the adaptive cruise control failure. That’s my amateur interpretation, anyway.
Patrick says to their knowledge all other changes should work on a 2026 in markets where JLR have not locked the CCF down via Secure Diagnostics.
Hoping this information helps anyone else who accidentally breaks their car trying to get the silly 007 logo to pop up.
That's interesting, good to know and thank you for sharing. Hopefully you'll get everything normalized, share here if it all possible. As long as your battery is charged, the chances of bricking the ECUs is minimal. I'd guess only if you pull the tool from the OBD port interrupting an upload, that could cause some serious issues.
And it is very possible JLR might have changed a few things internally to accommodate the locking of the CCF files in some countries, hence the no-go on changing the splash logo on '26 models onward.
Yeah reverting that one CCF change to “mainstream vehicle” fixed all my problems. Crazy, it’s the last thing I would have suspected. It’s ironic, this is the very first thing I changed, thinking it would be the lowest possible risk.
One tip I learned the hard way coding CCF on my cars. Change *one* thing at a time. Then test functionality or for other errors. Then onto the next.
On my 2026 110 V8 today I tested the GAP tool on two parameters:
1 - Remember last start/stop state - works perfectly
2 - Keep DRLs on when the turning signal is active - does not work as expected. When the turn signal is on, the white halo goes away and vice-versa alternating. Before the halo would just turn off completely while the blinker was active. So the CCF 'do nothing' setting doesn't work. I think it's because the DRL 'voltage control' setting is off from factory and I didn't want to mess with that.
Maybe someone who either has a '26 outside of USA or knows how to do this can chime in on these settings. I haven't tried the dim setting because the voltage control I assume would need to be on.
And I think JLR changed the CANbus numbers / names for the auto-fold / unfold exterior mirrors as well. I only see the unfold function that I can turn off but not the fold function. I'm trying to deactivate this every time the car is locked. I can manually fold/unfold when I need it, less stress on those motors and gears.
