GAP IID Tool Summary
Old Oct 18, 2025 | 09:00 AM
  #541
pjeski's Avatar
Originally Posted by isugoo
Auto brand hold should be in your PIVI system as an option. It enables to brake when your Defender is in full stop. So yes, if you're at complete stop and putting your gear at N, it'll enable auto brake hold. Quite convenience feature in street driving.
For auto leveling, I'm interested as well but not sure how to enable it. I would like to learn more from other members as well!
There’s more to auto brake hold than the Pivi setting. You can turn it off in the Pivi, but a moderate push on the brake pedal will still engage it. It’s called “demand brake hold” Why JLR thought that was a good idea, I’ll never know. But by turning off MultiCAN 711 Auto Hold, you disable both functions, which, in my opinion, is much better than a car that will engage brake hold when it wants to.
Old Oct 18, 2025 | 11:57 AM
  #542
jwest's Avatar
Hey, I know this page is about the Defenders but do you know anything about changing how the shift controller works on my L405 RR? For example, in my lr3 if I start engine, shift to N, I can coast off my driveway into street, then simply change into D while I'm rolling.
This is NOT allowed in my RR. Sure I can coast indefinitely but in order to push down and dial into D, the vehicle has to be totally stopped first, or so close to stopped that it is practically the same situation.
Old Oct 20, 2025 | 03:42 AM
  #543
Zamordysta's Avatar
7th Gear
Hi guys,
Thanks for your help and advices I thought it is something wrong with OBD device or I'm doing something wrong, or maybe still doing :P basically what I'm doing is that first of all I'm turning ignition on (without break pedal so engine not starts) and then when I press apply changes I'm not touching anything (ex. break pedal ) until I get information that changes was applied successfully. I was trying to reset media when I had to use car durning the weekend couple times and no luck yet
Originally Posted by Sir Lands-a-lot
I would suggest perhaps - after an update - shut down the car and double lock. This tends to shut down the many systems. And also wait maybe 15 minutes?
And failing that, yes ignore and keep driving for a week or so as some people experienced, things then kick in.
Double lock you mean double press button on door handle? Does it work if I double press locking button on remote?
Old Oct 22, 2025 | 07:20 PM
  #544
quikoitaly@gmail.com's Avatar
Exclamation
Hello, I am an happy owner of Defender 3.0L 250Hp diesel, 2021, FIRST EDITION model.
During my last attempt to enable park assist function, although I followed all instructions carefully, as usual the function did not work. I tried few times in the past too, with no success.
Questions:
1) is it that park assist function work on some models only ? This is the only reason I see for mine not to work.
2) unfortunately after last attempt above I got left with 2 errors (which are still here) , although I resetted the PIVI twice as instructed and switch the car off for long time. Errors as follows:
2a) Emergency brake assist
2b) drive with caution as 2 wheels traction is working only
Any help ?
Old Oct 29, 2025 | 08:45 PM
  #545
davidrosenbloom's Avatar
8th Gear
GAP TOOL IID ISSUE OBD CONNECTIVITY
I have a GAP tool properly licensed for both my 09 L322 and 12 L322’s. I am at least experienced or very experienced with OBD readers and I have had a connectivity issue before (dead OBD) on a JLR product which this does not feel like. Heres my problem(s).
On the 09 Gap lights up green and then shows me everything including her panties all the goodies underneath-I mean stuff I don’t even ever want to see.
On the 12 however, Gap lights green shows voltage sees VIN says hello, and can do a bunch of things BUT doesn’t have any menu items for the PCM or deep menus like on the 09 for the RLM suspension no matter what I do or how I go in. Period. Its no Gouda.
To be clear, the OBD ports are different and on the 09 I count 11/16 connectors (female) on the OBD and on the 12 I count 12/16 connectors. I’ve read everything and watched everything. Reconnects fine (12 times) however, on the 12, I get the “Download Manual” interrupter with an “Abort” or “Download” seeming “glitch” that will sometimes allow me to by pass it but comes up far more often than on the 09 where it does appear but I can usually bypass it after two attempts.
Additionally, it doesn’t matter that the car is running or not; the suspension can be commanded up or down but to be crystal clear its NOT NEAR the same depth chart as the 09 where I can see the temperature of the motor the pressure sensor etc. Yes I read and cleared faults; there were a bunch on the 09 but GAP didn’t care a bit- it was like an XRAY; however, on the 12 under “live values” PCM I toggle past and get zero (0) options just a blank page. The faults on the 12 were just three; a door locking mechanism fault, and two mirrors left and right heating element shorts. (I know… but I cleared them and even assuming they are literally crossed and somehow don’t draw enough v to trip fuse, how would this disappear an ECU?) The Gap sees 13 ECUs and counts them off; everything loads fine; not a connectivity warning save for what I’ve said – the download manual warning seems quite glitchy; because if I persist I can get past it and into the menus BUT not all of them, its much much worse on the 12 than the 09.
Has anyone experienced this issue OR know anyone that has had this issue. Its just not allowing me menus that it did on the 09 and everything according to GAP is properly licensed.
Does anyone suspect the OBD port and if so can anyone point to the wiring diagram on RAVE that shows how I can track wires back. Wiggling does nothing I have real doubts this is a true connectivity issue.
Old Oct 30, 2025 | 11:13 AM
  #546
CincyRovers's Avatar
I think your best bet would be to post this on the L322 discussion forum, as well as reaching out to GAP themselves - they have excellent customer support.
Best of luck, hopefully you get it sorted!
Old Oct 31, 2025 | 08:33 AM
  #547
abran's Avatar
Agreed to reach out to GAP.
gapteam@gap-diagnostic.com
Old Oct 31, 2025 | 12:12 PM
  #548
8th Gear
Sorted. But what a mind trip. I'd love to know what it was. dr
Old Nov 3, 2025 | 10:55 AM
  #549
Skyfall's Avatar
Originally Posted by PetarJ
​​​​Here is the list of changes that I had done to enable Matrix Headlights in my car. Everything is working as expected. In the menu - exterior lights - HD Adaptive Driving Beam toggle has appeared. Functioning as expected. I suspect not all of them are needed and I will update the list once it is verified.
  • EUCD-014 Headlights, TypeMatrix LED AFS123/IHB
  • EUCD-015 Headlights, SymmetryNot supported
  • EUCD-016 Dayrunning LightStandard Dipped Light for Vehicles with Dedicated DRL
  • EUCD-017 Dimmed Dipped HeadlightsNot supported
  • MultiCAN-459 MainBeamVoltCtrlDisabled
  • MultiCAN-459 DipBeamVoltCtrlDisabled
  • MultiCAN-459 FrntPosLmpVoltCtrlDisabled
  • MultiCAN-459 DRLVoltCtrlDisabled
  • MultiCAN-460 CornerLmpVoltCtrlDisabled
  • MultiCAN-460 FrntDirIndVoltCtrlDisabled
  • MultiCAN-460 FrntFogVoltCtrlDisabled
  • MultiCAN-460 AuxFrntLmpVoltCtrlDisabled
  • MultiCAN-468 FntDRLTypeIncorporated DRL and Pos
  • MultiCAN-471 MainBeamFdbkMechBCM receives fault data via LIN
  • MultiCAN-471 LowBeamFdbkMechBCM receives fault data via LIN + Tell Tale
  • MultiCAN-482 FntSdMkrDrvMechDriven via BCM
  • MultiCAN-485 HighBeamDrvMechDriven via BCM
  • MultiCAN-485 LowBeamDrvMechDriven via BCM
  • MultiCAN-636 AdaptDrvBeamEnabled
  • MultiCAN-636 Laser High BeamDisabled
  • MultiCAN-674 AFS123Enabled
  • MultiCAN-679 HeadlightsVariantHeadlamp_Variant_High_A ( mine is NAS so A, other regions : B, C)
  • MultiCAN-693 ADB InitialisationFitted
  • MultiCAN-704 Adap Dry Beamseg4 Segments
  • MultiCAN-706 Dyn Bending LightFitted
  • MultiCAN-750 High Beam LightsNot fitted
  • MultiCAN-750 AHB System StatusAHBA Not fitted
  • MultiCAN-814 Laser High Beam MenuIndependent Laser setting
  • MultiCAN-834 HD Adapt Drive BeamNot supported
I just got a decent deal on a set of LHD L8B2-13W029-HJ and L8B2-13W030-HJ headlights. Hoping to have them in the next week or two and get the installed and programmed.
looking forward to the brighter lights and AFS more than the ADB honestly, but will be nice to have that also!
Old Nov 6, 2025 | 02:57 AM
  #550
Zamordysta's Avatar
7th Gear
Are you sure (if yes, where did you find this information, if you can say)
I have Evoque P300 HSE R-Dynamic 2020 from US market and in mine was Headlamp_Variant_MID_C
