GAP IID Tool Summary
Old May 12, 2026 | 11:37 PM
  #651
jwest's Avatar
Originally Posted by L460_Rocks
On my 2026 110 V8 today I tested the GAP tool on two parameters:
1 - Remember last start/stop state - works perfectly
2 - Keep DRLs on when the turning signal is active - does not work as expected. When the turn signal is on, the white halo goes away and vice-versa alternating. Before the halo would just turn off completely while the blinker was active. So the CCF 'do nothing' setting doesn't work. I think it's because the DRL 'voltage control' setting is off from factory and I didn't want to mess with that.
Maybe someone who either has a '26 outside of USA or knows how to do this can chime in on these settings. I haven't tried the dim setting because the voltage control I assume would need to be on.
And I think JLR changed the CANbus numbers / names for the auto-fold / unfold exterior mirrors as well. I only see the unfold function that I can turn off but not the fold function. I'm trying to deactivate this every time the car is locked. I can manually fold/unfold when I need it, less stress on those motors and gears.
I can check my octa but had never even thought about how the halo might behave when turn signals are on.
I do have my all of the lights able to be turned off when in park though.
Another one i like is allowing the fogs to be on "with" high-beams.
Old May 13, 2026 | 03:12 PM
  #652
L460_Rocks's Avatar
Yes there are many interesting settings. A quick update on my two LRs,
1 - '26 Defender 110 V8
  • I've disabled the fake engine noise and it does make a difference, the car is quieter now, I like it.
  • No luck on disabling the external auto-fold / unfold and keeping the manual fold/unfold functionality.
  • Fog + High Beams, works.
2 - '25 Range Rover P530 SE LWB (Twin Turbo BMW V8)
  • Also Disabled the fake engine noise, very small difference but it's even quieter now.
  • Same as the Defender on the auto-fold / unfold disabling feature. No dice.
  • Remembering the last state of the engine start/stop. It works, I'm so glad, I hated that thing.
  • Fog + High Beams, success as well.
Now I'm trying to find how to disable for life the utterly annoying open door chime with ignition or engine on and also have this mirror folding on locking up gone for both vehicles.
Old May 13, 2026 | 10:03 PM
  #653
skl49's Avatar
Need to reset the service indicator- without going thru the whole thread, anyone point me to how to do that with my GAP tool on my wife's '24 110 V8? Haven't used the tool for a while... TIA.
(it was almost worth the price of admission just to turn off auto stop/start!!)
Old May 13, 2026 | 11:35 PM
  #654
isugoo's Avatar
Try to earch google. I've seen it somewhere in the forum how to reset the service indicator in 3-4 simple steps without gap tool.
Old May 15, 2026 | 12:14 AM
  #655
L460_Rocks's Avatar
For those of you who disabled the automatic exterior mirror folding/unfolding in the Defender, did you also lose the manual folding/unfolding function? It is supposed to work when you press both mirror selection buttons at the same time on the driver's door.
When this was turned off in my '25 Range Rover, the 'digital' button on the door disappeared, thus no manual control whatsoever.
Old May 15, 2026 | 02:22 AM
  #656
pjeski's Avatar
That is what the setting does. Can’t have one without the other.
Old May 15, 2026 | 03:38 PM
  #657
L460_Rocks's Avatar
That's a weak implementation of the functionality IMHO. If I still want to fold them when needed (tight spaces, car wash run, etc) I should be able to manually fold/unfold while not having the car do it every single time it gets locked. In my older GLS-63 this was a simple choice on the screen, JLR should implement this in the Pivi Pro, something like "Auto-Mirrors-Fold on lock - On/Off" and keep the manual folding via buttons on the door always available.
Edit:
I tested MultiCAN-463 DRLBehWhilstDIsAct which is how the halo behaves when the indicator is on, the Dim option works and I kept it that way instead of the factory Off option. As mentioned before, the No Change option which I thought would keep the halo on steady at full brightness in fact alternates on/off with the amber indicator, looks very odd.
I also tested MultiCAN-787 Speedo Minor Scale which is Disabled by default. It does nothing when Enabled. I thought the speedometer circle would change or the speed number at the center would change but nothing happened.
Old May 20, 2026 | 07:52 PM
  #658
L460_Rocks's Avatar
Default About exterior mirrors fold/unfold OFF
I have received a reply from JLR... I'm not holding my breath.
Thank you for contacting the Land Rover Customer Relationship Center regarding the exterior mirror auto fold/unfold functionality on your vehicles.
We appreciate you taking the time to share your feedback regarding the ability to disable the automatic mirror fold/unfold feature while still retaining manual fold/unfold operation through the vehicle controls. Your comments and suggestions regarding a software option or toggle within Pivi Pro have been documented for review by the appropriate teams. Customer feedback plays an important role in helping Land Rover evaluate potential future enhancements and functionality updates.
Although we cannot guarantee that a future software update will introduce this functionality, we do appreciate you bringing your concerns and recommendations to our attention.
Thank you again for your feedback and for your continued loyalty to the Land Rover brand. If you have any questions or need additional assistance, please contact us at [...]
