GMRS radio installation
Old Mar 16, 2024 | 02:34 PM
  #31
Chris.Gio's Avatar
A few progress pics..
here the driver seat is out—oh you can see my radio and speaker mounted on the removable thing. More pics on that later.
Here I’ve routed the antenna wire up to where I’ve drilled a hole for the plug.
a shot of the antenna lead coming in (other side goes center armrest, under steering column, firewall, engine bay then outside antenna).
Old Mar 16, 2024 | 02:46 PM
  #32
Chris.Gio's Avatar
Here is my “rig” where radio and speaker are bolted yet removable. The face plate will be above rear view via Plumb case. I test routed the wire from radio to face plate via dash and a pillar and found a way I’m happy with. But Plumb piece doesn’t come for another week.
Old Mar 16, 2024 | 02:51 PM
  #33
Chris.Gio's Avatar
Last set for now. Here I’ve done the hard wiring via battery under passenger seat. Another custom drilled hole plus shaved a half hole in the battery cover for wire.
Old Mar 17, 2024 | 03:28 AM
  #34
Defendit..'s Avatar
You could get easy the wire under the rubber floor lining from battery to the console..
Old Mar 17, 2024 | 08:20 AM
  #35
Chris.Gio's Avatar
I thought about that but didn’t see an obvious route without removing more plastic. The seat rails are elevated in this area/ above that channel so I don’t believe anything is touching the wire as is. That and it’s about impossible to see the wire with seat in place meant I did it the slightly easier way.
Old Jan 18, 2026 | 08:12 AM
  #36
LelandRS's Avatar
Default CB Mike mount
Great install. Really like the bracket to hold the mike. Where can I get one?
Sounds Incredible made this insert panel.
dcaven
May 8, 2020 10:59 AM
Dizzco II
Sep 7, 2016 08:09 AM
cmb6s
Mar 23, 2016 02:33 PM
grandkodiak
May 10, 2012 08:38 AM
yloDiscoII
Jul 15, 2011 11:04 AM
