Heated Steering Wheel
Old Dec 20, 2025 | 03:24 AM
alps.defender's Avatar
Default Heated Steering Wheel
Heated steering wheel stopped working, light goes on and stays on, doesn’t go out like some of the other posts. Has anyone managed to fix theirs without installing a new wheel?
Old Dec 20, 2025 | 04:26 AM
wcc18999's Avatar
When the steering wheel reaches a certain temp, the heat output is reduced to prevent overheating. If yours does not do anything, there may be something wrong with the heating element. I would have the dealer check it especially if your car is still under warranty. Also, whenever the temperature is above 60 to 70 F, the heat output is limited. Try it in cold weather and if nothing happens, take it to the dealer.
Old Dec 20, 2025 | 11:04 AM
Jbiggzs's Avatar
Also if you have drive mode set to Eco mode it will turn off the heated steering wheel.
Old Dec 20, 2025 | 12:59 PM
wcc18999's Avatar
I did not know that. Thanks for sharing this information.
DISCOFETA
Mar 14, 2025 11:02 PM
Grum.man
Mar 8, 2025 11:41 AM
Needledown
Jan 1, 2023 09:00 AM
nashvegas
Nov 22, 2022 10:32 AM
JarekDeclan
Range Rover Velar
Feb 12, 2021 10:49 PM
