My 2020 110 P400 Mod Journal
Did the 30mm spacers work with the factory lug nuts?
Hey Jesse,
i am waiting for a set of black rhinos 20x8.5 et +10 and trying to choose a tire size. i have committed to a 1.0 lift and no more. the shop is saying 275/60/20 but from what i am reading most are having issues with the 60 side wall.
with your spacer setup your net offset would be close to my black rhinos. did you ever try this with your 275/55/20 without lift and did it rub. believe you mentioned with the lift there was no issues
Yes, they worked fine fitment wise. The K02 tires were the issue for balance and shape. After replacing 3 of the original 5 for warranty reasons within the first 140 miles and have two more that wouldn't at all balance I ran away from those garbage tires. They were simply terrible quality control versus the Nitto.
Thanks for all of the pictures on this thread. It seems like you have a good bit of time on off road or terrain tires. Just curious what your take is on quietness and highway performance for your off-road tires? Are they noisy to the point that long highway travel would be annoying? Do you really have any noticeable lack of grip compared to an All Season on contaminated highways surfaces?
Hey Jesse,
I wanted the wider stance for aesthetics and stability. Eventually I just had a set built that replicated the offset I desired.
I am in the automotive manufacturing corridor myself and the backorder/supply chain issues are insane right now. I've never seen anything like it.
