My 2020 110 P400 Mod Journal
Old Jul 5, 2021 | 05:37 PM
  #61
GrouseK9's Avatar
@Defender13 - Here's a version. I believe the metal plates are ~7" so if you want something close in size here you go: [Link]. I'm waffling between a metal one that is riveted and a decal. The former looks better, the later is easier to remove in case of need/resale.
Old Nov 24, 2023 | 04:52 PM
  #62
rkcLR5150's Avatar
Question wind deflector w sunroof?
Originally Posted by JesseRohr
Next phases:
The wheel is a 20x8.5 with 41.5mm offset. With the spacers the wheel is pushed out 30mm creating a 20x8.5 with 11.5mm offset.
H&R makes a set of 25mm spacers as well that would work. 20x8.5 with 16.5mm offset would be that functional setup.
25mm set - Part number 50757257 (you need two)
30mm set - Part number 60757257 (you need two)
30mm wheel spacers and new BFG K02 Tires:
Windows tinted 15%:
Attachment 55205
Attachment 55206
Nitto Ridge Grapplers swapped in instead of the BFG after three were warrantied for out of spec shape. Also JLR factory Raised Air Intake and Cross Bars installed:
Attachment 55207
Proud Rhino 1.0 lift arms installed:
Attachment 55208
Attachment 55209
FrontRunner Slimline 2 rack (For OEM Rails) installed:
Attachment 55210
Attachment 55211
Attachment 55212
Attachment 55213
Attachment 55214
Truck looks great - how are you using that wind deflector ? Sunroof on yours? I've got the same rack, trying to work out the wind noise issue. TIA. -Kris
Kris
2021 Defender 110X
whowa004
144
Sep 3, 2024 11:02 PM
The Deputy
16
Nov 4, 2022 07:11 PM
Docgrievous
Jan 24, 2021 06:31 AM
dmannrover
Jul 31, 2019 11:57 AM
