New 2020 Defender Lift Kit by Johnson Rods
Old Mar 30, 2022 | 08:50 PM
  #121
bobbo28's Avatar
Thank you Nanozic. The 275/55/20's work (no rub) without the lift... was adding the lift to your tire/wheel size worth it (considering it was unnecessary)? One of the reasons I'd like to add the 1.5" is to accommodate a slightly larger tire and of course b/c it looks bad ***!
Old Apr 2, 2022 | 08:55 AM
  #122
Nanozic's Avatar
I'm not running a lift with my setup. If I were to run the size you're looking at, I would. Although I don't get any rubbing at normal height with not lift, I did take a heat gun to the front of the fender liner to push it out and get a little more clearance because sometimes at full turn lock the tire would 'kiss' the fender liner..
Old Apr 3, 2022 | 07:52 PM
  #123
twallace80's Avatar
Default 1" Lift w/ 33" tires
I've scoured the forum and i'm sure I missed it somewhere.
I have a 2020 Defender 110 SE 6 Cylinder. Front & Rear mudflaps.
I want to put a 1" lift on the truck and go with 275/60/20 wheels/tires. Will I have any rubbing or issues based on what everyone is seeing?
Thanks!
Old Apr 20, 2022 | 11:43 AM
  #124
Johnson Rods's Avatar
LR Forum Vendor
Default NEW 1 inch lift kit out now!
Check out this 2020 Defender running 275/70R18 General Grabber AT tires and our 1.5 inch lift kit. We also now offer a 1 inch lift kit on our website! Go check it out!
https://www.johnsonrods.com
__________________
Please visit our website: https://www.Johnsonrods.com
Follow us on Instagram: @johnsonrods
Visit our vendor section:Johnson Rods Vendor
Old Apr 25, 2022 | 03:41 PM
  #125
LR Forum Vendor
Time to hit the trails with a Johnson Rod lift kit.
We have a 1.5 and a 1 inch available for the new Defender and other models.
Check our website for options, wheels and pictures:
Defender Lift Kit: https://www.johnsonrods.com/defender-lift-kit
Land Rover Wheels: https://www.johnsonrods.com/land-rover-wheels
__________________
Old May 9, 2022 | 02:35 PM
  #126
wkcwkc's Avatar
Just put 1.5" Johnson Rods on the 30th Anniversary Edition. No others mods. Already looks better (picture is taken with the Defender at Normal ride height), rides just like factory to me. Installation took 30 minutes for all of them in the garage. Will be installing larger tires soon!
Old May 25, 2022 | 06:44 PM
  #127
LR Forum Vendor
wkcwkw:
Looks real good. I had a customer that recently replaced his steel wheels with the following wheels from our website which have more offset for a wider stance.
Check out the wheels here: Land Rover Wheels
__________________
Old May 30, 2022 | 09:17 AM
  #128
NoGaBiker's Avatar
Originally Posted by Johnson Rods
wkcwkw:
Customer chose to go up to 20s? On that truck? Seems an odd choice.
Old May 31, 2022 | 07:24 AM
  #129
GrouseK9's Avatar
I'm not throwing stones, because I've done a LOT to change my Defender to look the way I wanted it to look. So, I say it with respect - I think they changed it more for the looks of the 20"'s than knowing / caring about the off-road performance loss. A lot of folks (including me) have done a lot to drop from 20's to 18's. He decided to go the other way.
Caveat: I'm assuming those are in fact 20's. I can't tell from the pic.
Old Jun 10, 2022 | 05:00 PM
  #130
LR Forum Vendor
Yes, they are 20's he just did not want the 18 inch steel wheels it came with.
__________________
