New 2020 Defender Lift Kit by Johnson Rods
Old Mar 13, 2023 | 02:58 PM
  #151
Johnson Rods's Avatar
LR Forum Vendor
275-65-20 is 34 inches and will not fit without doing more mods to the truck.
I have seen many owners run the 33x12.5. If you get any rub, a wheel spacer may be used.
__________________
Please visit our website: https://www.Johnsonrods.com
Follow us on Instagram: @johnsonrods
Visit our vendor section:Johnson Rods Vendor
Old Mar 13, 2023 | 03:03 PM
  #152
LR Forum Vendor
Check out this nice D110 build using our Johnson Rod 1.5 inch lift and upgrades list below:
Warn Zeon winch installed
-Winch kit w/ custom painted cover
-Factor 55 Prolink
-Redbourne Alston 20” wheels
-Toyo Open Country MT (285/60/20) tires
-Johnson Lift Rods
-Xpel PPF
-Custom Painted D-pillars
-Bad *** tent Roof top tent
-Side ladder OEM
-Wheel Arch kit
-Rough Country rear lights (attached to tent for flood effect when up). Also on a remote key fob and work as additional back-up lights or if some ******* is tailgating me!
-Aluminum front skid plate
-rear tow hooks
-aluminum extrusions added to tent shell for full roof rack use
-custom painted engine cover
Inside:
-Custom cargo hatch with dual struts and latching handle for rear cargo area (no third row seating)
-Custom box made to house dual battery system and extra storage
-dual battery and Victron smart DC-DC charging system
-2200 W. Kreigger inverter
-custom 120v dual socket receptacle
-Custom voltage monitoring panel with 6 auxiliary switches
For questions on this build contact: John McLaughlin
john@perfect-itautofinishes.com
__________________
Old Apr 9, 2023 | 04:29 PM
  #153
916Defender's Avatar
5th Gear
Sorry if this has already been answered but can you run 275/60/20 k02s with just the 1” lift or is the 1.5” the minimum needed without rubbing?
Old May 11, 2023 | 11:34 AM
  #154
starbai's Avatar
Dont want to get flamed outta here. But I notice you also offer lowering links. Though I'm not seeing any pics of them installed anywhere. https://www.johnsonrods.com/product-...g-kit-1-5-inch
Is there a thread any where (can't find any in search) or any pics you could post up @Johnson Rods ?
Old May 16, 2023 | 10:32 AM
  #155
freddyk's Avatar
Any pics of aux switches panel?
Old Jul 14, 2023 | 12:57 AM
  #156
ORDPA's Avatar
[QUOTE= Some customers are using 30 mm spacers to get additional offset.
I see a couple times you reference the use of 275-60-20 tire and use of 30mm spacers. Do you have any pictures of this? Also I am not sure I understand how spacers would stop a rub? I have already installed the 1.5 inch lift and am planning on BFG KO2s in the size I listed on stock wheels. I am also adding fender extenders and would like to offset the wheels to take up the space but figured I would not be able to as it seems like others on other threads report creating a rub when spacers are used. Any advice or info would be great.
Old Aug 1, 2023 | 09:36 AM
  #157
23defV8's Avatar
Default Lift with 22s
I love the 22s but wish I had a more aggressive tire. Has anyone done the lift with 22s to get a little more sidewall on a bigger tire? Yes I know I should change wheel size. Wanted 20s on the v8 but the deal for below MSRP was on 22s and they are kind of growing on me.
Old Aug 1, 2023 | 11:44 PM
  #158
TheTank's Avatar
4wd High
Default 1.5” Johnson Rods.
Hi. Looking to install the 1.5” Johnson Rods. I like the look with 285x45. Any issues with a 20” Wheel? Also, I have OEM Mud-flaps. Any rubbing issues at full turn or at shock compression on an off road uneven surface?
285-45-22 with Johnson Rod 1.5 inch lift[/QUOTE]
File Type: mov
Old Aug 4, 2023 | 05:13 PM
  #159
LR Forum Vendor
For the 20" wheel you can run the 285-45 but the choices are limited if you want an off road tire.
__________________
Old Aug 4, 2023 | 05:31 PM
  #160
LR Forum Vendor
Defender with 1.5 inch Johnson Rod lift and 275-60-20 BFG KO2 tires
__________________
