No Lift tire size guide (work in progress)
Old Sep 2, 2021 | 09:00 PM
  #161
Mojave45's Avatar
Default Hse 400
Toyo AT3 275/55 r20, Redbourne Morland rims.
Old Sep 2, 2021 | 10:36 PM
  #162
tarmac's Avatar
Wheels look good do you know the offset? Is that stock height and any rubbing at all?
Old Sep 3, 2021 | 12:20 AM
  #163
Defendit..'s Avatar
You're so lucky to get the Toyo' s in 20" I have ordered 18" AT3 in January, still on backorder ( 265/70 R18. T)
Old Sep 3, 2021 | 07:14 AM
  #164
sblvro's Avatar
After watching videos of the V8 in deflated stock 22 tires in the rough, do we really need AT if we're just tackling the urban jungle?
Old Sep 3, 2021 | 08:01 AM
  #165
JSDefender's Avatar
5th Gear
Originally Posted by easyf
Nice work! which shop did you you get it done at in LA? would you recommend?
sorry just seeing your question. Wheel warehouse in Anaheim, good dudes. I’ve done the Lucky 8- 1” lift since then and it’s a perfect setup IMO.
Old Sep 3, 2021 | 08:50 AM
  #166
Mojave45's Avatar
Stock height.The wheels have a 25 offset, no rubbing
Old Sep 3, 2021 | 08:51 AM
  #167
Mojave45's Avatar
Not sure why you are having that issue, most places around me have Toyo Tires readily available...
Old Sep 3, 2021 | 09:55 AM
  #168
Jolly Rancher's Avatar
Default AT tires: pro and con
I wanted AT tires mainly for better snow traction. Plus, because the Toyo AT3s are 3-peak rated, you can go over mountain passes in winter in the PNW without worrying that you'll be required to chain up. It's not as good as a dedicated winter tire, but in the Seattle area, a 3-peak tire on a very capable AWD vehicle works very well year-round.
TBH I'm also happier than I thought I'd be with how the Toyos look on the vehicle. They suit it better than the Good Year Wrangler ATs that came on it. Highway performance day one was stellar. I like how the tire works with the suspension. Road noise might be a tiny bit worse than the Good Years, but that's to be expected with a more rugged tread pattern. It's a new tire and ATs are known for getting increasingly noisy as they get more mileage on them, so I'll definitely report back as they wear.
Old Sep 3, 2021 | 10:22 AM
  #169
Mojave45's Avatar
I have run the Falken At3 here in the Inland Northwest, and years ago the Toyo AT2. I have heard really good things about the Toyo At3,and here in North Idaho,heard that the wranglers were not as effective in the snow, ice, and slush we get a good amount of. Decided to go with the Toyo AT3. I will know pretty quickly if they were the right choice. By the way, I hear no noticeable noise difference with them on.
Old Sep 3, 2021 | 10:24 AM
  #170
sblvro's Avatar
Does it mean the Dueler AT revo 3 would be sufficient too? It is a quiet AT tire.
