No Lift tire size guide (work in progress)
Old Sep 7, 2024 | 08:55 PM
  #661
Mike_F's Avatar
Originally Posted by POPTOPP
google drive may work. I've accessed, but not created content. I suspect you could make the spreadsheet public with read-only access and post the link at the top of this sticky thread. You could also give rights to update to a few folks so you are not burdened alone with upkeep.
Not a bad idea. I'll play with that. Don't be surprised to find yourself one of those with write access...
Old Sep 11, 2024 | 05:23 PM
  #662
Vadiable Paradox's Avatar
Originally Posted by Mike_F
Great thoughts, thanks. Wikipedia turned out to be a dead end - the editors don’t want it to host “technical manuals” - so I’m a bit stumped for where to put the data. I suppose I could maintain a spreadsheet and post a screenshot of it when I get new data but that seems pretty inefficient.
Hoping someone else has a creative idea for where to host it.
github.com may be a perfect place for it. Get a free account, create a public repo, publish your data, voila. Markdown format is pretty powerful, it can look nice. In addition, you get a very nice facility for corrections and additions - GitHub issue tracker, and pull requests.
Old Sep 11, 2024 | 05:56 PM
  #663
GavinC's Avatar
Save yourself any bother. The thread can be summarized into one number.
The maximum actual tire size (not always the same as nominal size) for a no lift Defender. No rub in access height. Any tire with dimensions that meet this criteria will fit.
32.6"
Old Sep 11, 2024 | 07:04 PM
  #664
Mike_F's Avatar
32.6"
Fair point. And a reminder to check manufacturers' websites for actual dimensions, which vary significantly across brands and models of the same XXX/XXRY size.
Old Sep 11, 2024 | 11:00 PM
  #665
32.6"
Not trying to be facetious, but rather practical - will this also work with bump stop height? I'm afraid it'll be the only way it'll fit into my garage with anything sticking out above the roof rack (like Rotopax mounts) without reframing the door :/
Also, width? Will there be no rubbing with tires wider than standard at this diameter?
Old Sep 12, 2024 | 01:22 PM
  #666
GavinC's Avatar
Yes. I drop to the bump stops for my garage when I'm laden with skis and rack. 32.6" tire
No problem with this 265 section width on OEM rims.
OEM sizing option in winter is 275/55 R20 No problems going wider
Old Sep 28, 2024 | 06:23 PM
  #667
hewpac's Avatar
Default All weather 18” tires in Pacific NW
I have grown tired of the factory Wrangler AT 255/70/18 - I can’t stand their poor winter and wet snow performance and am in the PNW. Going to replace after 30k miles.
I do mostly mild off road, forestry roads, and lots of skiing road trips so slush/snow/hydro performance are most important. The Wildpeak AT4 in factory size is not XL rated and I really don’t need full A/T 99% of the time, so thinking of trying the BFG Trail Terrain since they have excellent winter reviews, good mpg reviews, low noise, and decent value.
Has anyone who drives wet winters tried these out on the 18” wheels?
Curious to hear what others are running who are skiers and want to stick with factory 18” size.
Thanks!
Old Sep 30, 2024 | 12:26 PM
  #668
MTROVR's Avatar
I have put 275/55/20 Nokian nAT tires on my 2024 Defender 110 S p400 without any rubbing in all heights. Very quiet tire with great off-road traction. I live the California Sierra Nevada mountains where we have a lot of rocky trails. I have a lot more confidence and sidewall peace-of-mind with these tires vs the stock Goodyear Wrangler Adventures. BTW if anyone wants my Goodyears they only have 1800 miles on them and zero on the spare, just reply to this message.
Old Sep 30, 2024 | 12:32 PM
  #669
MTROVR's Avatar
I have a p400 20 inch wheels using Nokian nAT 275/55/20 without rubbing at any height using the stock rims.
P.S. if anyone is looking for Goodyear Wrangler Adventure tires I have 5 with only 1800 miles on 4 of them.
Old Oct 6, 2024 | 02:01 PM
  #670
whitestallion's Avatar
3rd Gear
Question 22" ???
This thread looks like the biggest wheel size is 20", but I have 22" - how big of a tire can I use? Does anyone know?
