No Lift tire size guide (work in progress)
Old Jan 22, 2024 | 02:50 PM
  #521
flyingdice45's Avatar
3rd Gear
Originally Posted by johnsonmc2000
Failken Wildpeak AT4W 275/20/55 - Love them! I tried the Wildpeak R/T on a long road trip and loved for offroad but there was more noise than I wanted between 40 and 50mph. Exchanged for the new AT4 and just a great tire. D rated so good load rating and sidewalls. Car feels planted, nimble and just great. Off road in a muddy field didn't miss a beat.
Lucky you got em, they weren't available in time for me. Only thing I didn't like about them were the weight.. I got 10 ply Cooper's and they're lighter than 8 ply Wildpeak's. Would love to test them and see how they improved over the previous model though
Old Jan 22, 2024 | 08:32 PM
  #522
jshwon's Avatar
4th Gear
redacted
Old Jan 22, 2024 | 08:43 PM
  #523
jshwon's Avatar
4th Gear
Originally Posted by bobbo28
Air suspension... the Wildpeaks are a huge improvement and they look amazing. No rub in any of the three heights.
Based on your experience with the Wildpeaks do you think the 275/60/20 would work without rubbing? I've seen this size work with other tires but of course they're not Falken's. See on their site the 265/60 is 32.5" and the 275/60 is 33"
Old Jan 26, 2024 | 04:03 AM
  #524
NigelM's Avatar
MY22 110 with 20's. Just changed the tyres to Grabber AT3 275/55r20 and added 20mm spacers to the front and 25mm to the rear.
No rubbing even at full lock in Access mode.
In terms of width the fronts are now 1mm/2mm inside the wheel arch and the rears are about 5mm inside but only because of the camber they are carrying. In the Uk you certainly could not go any wider than 20mm spacers with a 275 tyre and remain legal at the front. At the back you could possibly push to 30mm spacers but it would be marginal.
Old Jan 27, 2024 | 06:30 AM
  #525
Chris.Gio's Avatar
I’m a fan of KO2’s but new car came with 22’s.
any thoughts on fitting a 295/50/22 on a defender 90? Not opposed to a 1” Johnson lift if needed…
Old Jan 28, 2024 | 06:40 AM
  #526
gurka01's Avatar
I am running 33.6 inch tires with a 2 inch subframe lift and they rubbed a little. I drove it for a while like that and eventually trimmed the lower bumper. At 33.7 and no lift (maybe 1 inch lift rod) I would expect you will need to start triming some plastic
Old Jan 28, 2024 | 09:19 AM
  #527
Chris.Gio's Avatar
got it thank you.
anyone trying 285/50/22? Hoping to squeeze in as much side wall as possible!
Old Jan 29, 2024 | 06:20 PM
  #528
mrego's Avatar
Originally Posted by Chris.Gio
got it thank you.
I would love to see this work, but holy cow! these are expensive MFs...
Old Jan 29, 2024 | 06:32 PM
  #529
Chris.Gio's Avatar
found this: https://landroverforums.com/forum/ne...0-tires-84708/
Old Jan 29, 2024 | 07:27 PM
  #530
LRDG42's Avatar
4th Gear
50 sidewall on a 22" rim may start to cause rubbing on the inside fender wells, that's why opted for the 285/45R22 Toyo AT3's on my 110x (see my posts above). 50 sidewalks on a 20" rim would work (less rim -more sidewall and visa vera.)
