No Lift tire size guide (work in progress)
Old Aug 14, 2025 | 03:31 PM
  #771
Unibrain's Avatar
Installed LS255/60R20 BFG KO3. Since this is the stock tire size, they fit fine.
Old Oct 3, 2025 | 07:03 AM
  #772
PMKColorado's Avatar
Default Mickey Thompson Baja Boss A/T LT275/55R20 - LT rub & ride
Can anyone confirm that the "LT" version mounted on 20" factory rims, air suspension, does not rub at any ride height? How is the ride? The LT version has thicker sidwall lugs and stiffer sidewalls...thanks
Old Oct 3, 2025 | 05:18 PM
  #773
MRomano's Avatar
3rd Gear
Originally Posted by jrjunior41
Can you post pics please!
Old Oct 15, 2025 | 08:47 AM
  #774
CincyRovers's Avatar
Looks like the 19" BFGoodrich KO3 has been delayed until next year per the BFG website. At least it still appears to be coming, though.
Old Oct 20, 2025 | 12:51 AM
  #775
jwest's Avatar
That's a strange chart considering that the BFG ko3 is currently available in E load range 265/60-20 but not on that chart. I have a set and it's the max/ideal size for my RR SV AB with some front fender liner fuss. I bet it would fit perfectly fine on the Defender with no mods whatsoever on a factory wheel like the 20x8.5 but maybe not as well on a 20x9.5 and/or wider offset.
Old Oct 20, 2025 | 12:54 AM
  #776
jwest's Avatar
Originally Posted by spikemd
After 50k miles, my General Grabber X3s are toast. Worn out and chunked up from many miles offroad. I tried to get the same tires as I have been happy with then, but General is no longer making them.
I went with 275/65 r18 BFG KM3s on stock steelies on my P300. I was happy with the KM2s on my P38 Range Rover and wore those down to nothing. So far, they seem to clear on access mode butnI haven't tested them on full articulation yet. A bit of rub at full stuff, I can live with.
I'm headed to the Continental Divide Trail next month for a week of trails where they will be tested.
wow! they finally made that tire in the perfect 32" size !!!! I'd have loved this on my lr3 but am now past all that and onto 34" tires.
Old Oct 20, 2025 | 01:09 AM
  #777
jwest's Avatar
I'm running LT265/60R20. No rubbing at any height.
That is really the sweet spot size. I have it on my RR SV AB and had to adjust the front edge of the fender liner but otherwise its perfect. I imagine the L663's have just a bit more clearance that makes these the perfect no-fuss choice. Mine are even on wider offset Iconisus 20x9.5 but the factory 20x8.5 with narrower offset would require no adjustments at all.
Old Oct 20, 2025 | 09:36 AM
  #778
That chart is only a list of sizes coming in 2026. Currently available sizes are not listed.
Old Oct 26, 2025 | 08:04 PM
  #779
Eitan's Avatar
How are your Iconisus wheels? I saw them on Ebay and the price looks great, and the fact they have a physical location in Vegas seemed reassuring. Curious what your experience has been with them.
Old Oct 27, 2025 | 06:26 AM
  #780
Default Mickey Thompson- Baja Boss A/T "XL" on 20"
P400 Dynamic X - installed 275/55/20 "XL" version on OEM 20 " wheels. I chose to go with the lighter tire option vs the LT. Snow performance, moderate offroad, light towing (offroad gear hauler), noise were prioritized. No rub at all ride heights. First impressions: Looks great, aggressive. Handling seems slightly softer than the OEM Wranglers, though, the wranglers had 48K on them. Ride quality on air suspension is very good. Slight vibration in steering wheel on certain surfaces, feels more like the aggresive tread than balancing. Noticable road noise at 55-60, but still quiet. Roof rack wind noise is more noticable at higher speeds.
