Is it normal for comfort mode?
Old Feb 19, 2025 | 09:24 PM
Hieu Nguyen's Avatar
Default Is it normal for comfort mode?
I’ve owned the Defender for about a month. When I reach a red light and release the accelerator, the car slows down, but I feel like it sometimes light jerks a few times before coming to a complete stop. It’s like a person running, feeling tired and breathing unevenly. I experience something similar when I accelerate; the car seems to speed up very abruptly instead of gradually. Is this normal when I’m using the comfort mode, or is there something wrong?
Old Feb 20, 2025 | 08:55 AM
CincyRovers's Avatar
Assuming you're under warranty, take it to the dealer and have a technician or service advisor ride with you so you can show them the problem. It sounds to me like the transmission will need to be recalibrated.
Old Feb 20, 2025 | 02:15 PM
Zondar's Avatar
The sensation you describe while decelerating to a stop just sounds like the transmission is shifting down a few times, as it normally does. With each shift, there's a small change in engine braking that you can feel. You can feel that even when braking lightly. Brake heavily and the braking will mask the shifts. If that's what you are feeling, then this is normal.
The abrupt acceleration is probably just the boost kicking in. Also normal.
It doesn't sound like there's anything wrong to me.
Old Feb 20, 2025 | 03:10 PM
Jamborick's Avatar
I feel like the start/stop causes the car to jerk when slowing down, actually stopping the engine before stopping the car. The first thing I do after starting the car is turn it off.
Old Feb 20, 2025 | 04:04 PM
Yes. I also feel this issue when lightly brake. Your car is same?
Old Feb 20, 2025 | 05:03 PM
Zondar's Avatar
Yes, it's normal and my car does the same.
But the engine start-stop should absolutely not turn off the engine if the car is moving even a little. Only at a complete stop.
Old Feb 21, 2025 | 08:47 AM
Auto stop/start on the MHEV can shut off the engine at 2-3mph and use the 48v system the rest of the way. This is how most MHEV systems work and it is a lot more unintrusive and seamless than auto stop/start on conventional ICE vehicles. Some vehicles with larger MHEV batteries, mainly Audi and Mercedes products allow the auto stop/start to activate as high as 5-6 mph, use the system to provide torque fill to eliminate turbo lag, and allow the engine to turn off when coasting at high speeds.
Audi introduced a new MHEV plus technology that allows for full electric driving at low speeds (i.e. in stop & go traffic or slow city driving) and provides more boost to the ICE engine. This is debuting on the new A5 and Q5, but will not be available in the US, as our emissions regulations are lax compared to the EU. It is very interesting and impressive tech and worth reading the press release about it: https://www.audi-mediacenter.com/en/...-at-audi-16470
D110Xd
Oct 7, 2024 12:16 PM
cznser
Nov 20, 2023 05:56 PM
woodentom
Jul 28, 2023 02:28 AM
Tony Y
Mar 4, 2023 09:28 PM
Yoyo007A
Dec 7, 2021 08:42 PM
