Off-roading advice please!!
Old May 5, 2025 | 07:17 AM
  #51
honolulugator's Avatar
Originally Posted by POPTOPP
You are absolutely correct - the amount of travel on the typical bottle jack won't get your Defender high enough to get the tire off the ground. What I carry is a jack stand with a detachable base so it packs nicely beneath the load space floor. I jack up the Defender, place the jack stand, add the bottle jack extension and jack again. Sounds complicated, but it still takes less time than using the factory scissor jack. https://www.amazon.com/dp/B0007XTGCI...n_title_1&th=1
thanks… was thinking that was what people may do. I looked at the lower control arms… would probably need more info before I decided to jack there.
Old Jun 5, 2025 | 12:11 AM
  #52
Vadiable Paradox's Avatar
The product page says, quote, "not recommendable for big Pick-Up truck, Truck, too big off-road SUVs etc" and lots of people complain about these stands being too short and bases too small - did the seller pull a fast one and replace the product, could you please take a look?
Old Jun 5, 2025 | 06:44 AM
  #53
GrouseK9's Avatar
@POPTOPP - That's brilliant!
I think there are two scenarios when I work on my vehicles: in the garage (or there abouts) and in the woods (or like that). What I do in the former is a LOT better because I have a lot more tools and stuff. In the woods, it's usually a lot more sketchy. In my defense (no pun intended...) when jacking in the woods, step one is to slide the spare under the Defender near the tire. Then I perform all the sketchy work in the world. Worse case I have something to cushion the blow. After removal of tires, I smoothly/quickly/gently switch the two tires. When all is complete, put the dead tire back on the back. Is this recommended by anyone with a lawyer around? Heck no. Do I advise it? Heck, heck no!! But, it works for me and ymmv. For those of you who need plugging practice, if it's not carnage on the sidewall - THEN is an excellent time to practice!
Old Jun 5, 2025 | 09:20 AM
  #54
POPTOPP's Avatar
Well, it's a 3 ton jack and in my use case, its supporting less than half the vehicle weight. Furthermore, the stand is a heck of a lot more stable than a scissor or bottle jack.
Old Jun 5, 2025 | 09:25 AM
  #55
POPTOPP's Avatar
Sliding the spare under the vehicle is a neat idea. If anything should happen while the wheel is off, it might prevent the whole thing from crashing down on the rotor and brake assembly.
Old Jun 5, 2025 | 09:29 AM
  #56
POPTOPP's Avatar
Originally Posted by A1C6
Hello all!
In this thread I am seeking out some advice for what to bring off-roading in a Defender. Firstly, let me explain what I’ve got:
  • 20” w/ GY AT tires
  • Front tow hoop exposed, two rear tow hoops
  • TJM tow hitch receiver shackle
  • Two different tow ropes, one of which can be knotted easily around the factory tow hoops
  • Two (extremely cheap) recovery boards
  • Factory jack
I do understand that this gear is terrible, hence why I am seeking advice for what to get. Last trip we got a flat and had to change the tire with all the factory equipment. Mercifully there was a flat area just nearby. Unadvisable? Keep in mind we don’t go off-roading every weekend, but we do like the thrill/accomplishment of it and would like to do it more. For any aussies (looking at you @MiltonMan ) who know the south east Queensland area, the main places we like to go are Mt Mee and Fraser Island.
I just re-read the original post. Don't know if it was pointed out anywhere in this thread, but you should never knot a tow rope around an attachment point. Use a proper shackle. Knotting a rope may creates a weak point (depending on the type of knot) and may bind so tight that you'll have to cut it to remove.
Old Apr 13, 2026 | 10:49 PM
  #57
Originally Posted by GavinC
Garmin inReach has been useful.
That it is. However, Garmin's Android apps kill Android Auto outright (showstopper for me, offroad maps are usually on the center console), so I ended up using Zoleo instead. More useful as a communicator (together with a phone, not standalone), but it is bigger, heavier and less hiker friendly than inReach.
Tim0617
Oct 28, 2025 11:51 AM
apagan@gmail.com
Aug 12, 2023 09:09 AM
Eitan
Nov 15, 2021 12:17 AM
Bjs1234
Apr 12, 2021 09:54 AM
Bago
Feb 20, 2018 06:39 PM
