Is this Panel Removable? What's underneath?
Old May 24, 2023 | 09:38 PM
Adamalli's Avatar
Originally Posted by sblvro
Did you install a battery tender hook up in this?
no battery tender just a dc2dc charger. That is the renogy device in the picture.
Old May 24, 2023 | 09:40 PM
Adamalli's Avatar
Originally Posted by AAJR
Thank you for the picture. I take it you only partially released the left side panel then and there was enough space to fish the wires then? I saw the Powerfuluk video. I would much rather not tear off that side panel. It's unfortunate that his car did not also have the vent/cooling bump out there, as it would be helpful to see what obstructions might be there.
Thanks again for your help.
Alberto
I did not remove that panel at all. I just drilled a hole in the top and pushed thick piece of aluminum wire down until it came out the bottom. Took a bit of fangaling but I got it out the bottom eventually. Then pulled the wire back up and through.
Awtargum
Feb 1, 2022 07:10 PM
DillJLoc
Sep 14, 2021 02:13 PM
Z4nr
Jul 7, 2021 12:58 PM
Arun Chandrakanthan
Discovery Sport
Dec 7, 2017 07:52 PM
TATZOO
Jun 17, 2012 07:45 AM
