Passenger Door Will Not Lock?
Old Feb 3, 2022 | 10:35 PM
Patrick Matheson's Avatar
6th Gear
Question Passenger Door Will Not Lock?
Hi. Defender 2020 110 S... The passenger door will not lock either by pressing the internal switch, via the FOB or when the car reaches 18 kph (as set via the software) Thoughts? Thanks
Old Feb 4, 2022 | 11:33 AM
RH5555's Avatar
You could check fuse 27 in the passenger compartment fuse box. That's the one for the passenger door.
Old Feb 5, 2022 | 08:32 AM
WTFChuck's Avatar
When I took delivery of my MY22 I had the same issue. Wouldn’t lock by any means. Tip-off was that when I locked the vehicle with the fob, I would get a beep-beep, which indicates a locking fault. Went right back to the dealer and they had to do some software tweaking, but it was fixed promptly. Do you get the double beep sound? It’s an easy fix.
Old Nov 26, 2023 | 10:47 AM
BRowe's Avatar
Default Defender locking malfunction
My Defender '22 has the same beep-beep locking error you describe. Can you refer me to your dealer in case my dealer in Ohio isn't able to correct via software adjustment?
thanks,
BRowe
Old Nov 26, 2023 | 01:48 PM
WTFChuck's Avatar
My dealer replaced the locking module. I deal with Treasure Coast Land Rover/Jaguar in Fort Pierce, Florida.
robbyb20
Mar 10, 2021 09:26 AM
mooni
Jan 5, 2015 09:38 AM
bsnapp818
Mar 2, 2010 01:52 PM
seamuspg
Sep 18, 2009 05:59 PM
llPANCHOll
May 2, 2009 02:39 PM
