Permanently disabling auto start/stop
Old Nov 29, 2021 | 01:17 AM
  #111
Mark1107's Avatar
I unplugged mine battery cable I love it. It’s awesome,
Old Nov 29, 2021 | 10:49 AM
  #112
Magnumforc's Avatar
I remember in one of the Jags that there was a 3 or 4 wire plug that connects to a module next to the fuse panel. This wire supplies power to the start/stop system.
Unplugging it throws an error when the car is started. Something like "start/stop not available" but that clears and no other systems are impacted.
No idea if the Defender has a similar set-up but it would be in the good book if it does. Just have to find it.
https://landroverforums.com/forum/20...0-p400-109129/
My 2016 Jaguar XF-S had a single wire attached to the battery under the trunk and simply disabling that eliminated the stop-start with no other issues; had it that way for 5 years. It did not affect the battery monitoring system or any other function. Wish they had used the same method on the Defender, although neither of our auto stop-start has ever functioned since day one and we are happy with it as is.
Old Nov 29, 2021 | 07:02 PM
  #113
gurka01's Avatar
Mine is unplugged a d has been for almost two years. Would not ever consider going back
Old Nov 29, 2021 | 08:15 PM
  #114
AvoTow's Avatar
Originally Posted by Muppetry
But it is really easy to turn off - just one extra button push when starting the vehicle.
I completely agree but sometimes I let my wife or my father borrow my vehicle. While I appreciate Start/Stop systems for the environmental and MPG benefits, my Defender as well as a few others have completely shut down at stop lights. It led to a small fender bender when an impatient driver attempted to speed past my wife as she was restarting the vehicle. It would be good piece of mind to just have it disabled. This is a great tip.
Old Nov 30, 2021 | 07:47 AM
  #115
drcoop's Avatar
Interesting finding this morning... After unplugging the BMS wire from my battery ground terminal, all ran well with startup, no faults or errors noted, no differences noted with operation and no auto-start/stop engaged. In fact a little symbol shows up on dash when it would normally engage the system with a line through the Auto Start/stop symbol and engine keeps running. Planned to continue running this "BMS Unplug experiment" and report back over time with any negative side effects..... BUT within a few minutes noted the steering wheel not heating up, even though I had turned it on when I started the engine and the LED on the steering wheel was on. Turned it off and back on, and nothing. So pulled over, plugged the BMS wire back in and steering wheel heated up. Heated seats did not seem to be affected. Temps only in high 40's this morning, so nothing extreme.
So this is enough of a reason (at least in the winter) for me to leave the wire plugged in and just manually turn off the system.
Old Nov 30, 2021 | 08:41 AM
  #116
Kev M's Avatar
CRAP - that could be enough to keep me pressing the button....
Old Dec 3, 2021 | 07:01 PM
  #117
gurka01's Avatar
Unrelated or seems to be. Again, two years unplugged. Heated steering wheel works no problems, the led is on... Etc. Maybe the difference in the configs and options but my wife's RRS 2020 is the same. Heated SW no problems +led.
RRS P525 and the Defender is a 110-X
Old Jan 31, 2022 | 07:07 PM
  #118
ericm's Avatar
unfortunately my OTA software update on a 21 P400 X-Dynamic HSE last week enable this "feature" so I'm now having to deal with the "convenience" of this.
Old Jan 31, 2022 | 07:08 PM
  #119
ericm's Avatar
sorry for the extra post
Old Jan 31, 2022 | 07:57 PM
  #120
Dewman7770's Avatar
The OTA updated my p400 and now the auto start /stop started to work for 1 day. Next day engine light came on and says high idle and stopped working. Thanks LR
