Rattle on rough roads
Old Jan 11, 2022 | 05:35 PM
PaulLR's Avatar
You can just pull that trim piece off and add foam or felt. So many of the Defender interior pieces just snap together. It's like a giant version of the Defender Lego model.
Old Jan 11, 2022 | 08:51 PM
TCole's Avatar
Originally Posted by GrouseK9
Agree with @PaulLR . Buy this and keep it in your glovebox (in a sealed container....):
https://www.amazon.com/Genuine-Honda...1825469&sr=8-3
Does this stuff help with wind noise? Hoping it does.
the noise on the highway close to my driver side-door is up to mid 70 decibels (per my Apple Watch app). Thanks.
Old Jan 12, 2022 | 07:44 AM
_Allegedly's Avatar
Yes. It soaks in and swells the rubber for a tighter seal.
You might need your Apple watch checked though. 70db is as loud as a vacuum cleaner or small generator. 75db is like standing at the edge of a highway or a lawn mower.
Old Jan 12, 2022 | 08:28 AM
TCole's Avatar
Thanks. Yes, the wind noise is VERY loud on the highway. Callers on the phone always ask if I have my windows open. Maybe related to my sunroof rattle which the service rep recommended be replaced at the body shop (a component or carriage is bowed). Waiting for a new sunroof to arrive. Anyway, ordered the grease. I’ll try it out.
Old Jan 12, 2022 | 01:29 PM
PaulLR's Avatar
Originally Posted by inater
This is currently a very annoying issue for me....
I should have noted that to get that piece off you need to take off the grab handle at the far left side of the dash. (4 big exposed torx bolts ) There is one small black torx screw that holds the left side of the trim piece. Remove the screw then just pull the trim piece toward you. I lined all 4 outer edges with strips of adhesive felt. Seems quiet so far.
Old Aug 3, 2023 | 04:00 PM
TheTank's Avatar
4wd High
Default Same Rattle Noise
Originally Posted by Count Laszlo
I have a strange faint rattle over the right side top on the drivers side. Tried to identify it but now I just live with it. I think whatever it is, is between the headliner and I’m not pulling that down. To me it sounds like a wire wobbling around up there. Anyway it’s not a bad rattle at least mine and easy to live with.
Hearing a rattle noise - driver’s side by steering column on bumpy road surfaces. Any ideas?
2020Defender1stEdition
Sep 24, 2021 02:36 PM
tsb
Aug 14, 2021 01:49 AM
Crash458
Nov 17, 2016 07:15 PM
twaszak
Feb 5, 2013 12:15 AM
pickps
May 14, 2007 12:42 PM
