Removing tailgate studs
Old Aug 26, 2024 | 03:33 PM
Defendeth's Avatar
Default Removing tailgate studs
At the ~20 minute mark in @PowerfulUK's
... Simon hammers out 2 screw studs in the tailgate. Has anyone else successfully done this?
I've tried a 2.5lb hammer, a 2x4 with a metal plate screwed into it, and a heat gun. Nothing seems to loosen it.
Old Aug 27, 2024 | 07:08 AM
GCSchmidt's Avatar
I recently installed the hi-lift jack carrier. I used a dead blow hammer and a 2x4 (like you) and had to pound the living hell out of it to get the stud out...but it did come out. I think using the dead blow hammer made the difference...I started with a 3lb sledge hammer with the 2x4 with no luck. I was a little timid on hitting it at first but after a while I really started waling on it with the dead blow. I did loosen the nut and made it flush with the stud to have more surface area to strike and protect the threads just incase I put it back to factory.
Old Aug 27, 2024 | 08:24 AM
bgh20DEF's Avatar
5th Gear
Why don't you just remove the whole tire mount and then you can hammer it out without damaging the tailgate.
Old Aug 27, 2024 | 08:32 AM
GCSchmidt's Avatar
The stud holds the tire mount to the tailgate. I didn't experience any damage to the tailgate with my "careful" force application.
Old Sep 4, 2024 | 01:58 AM
Defendeth's Avatar
Love the hi-lift jack carrier. I ended up going with @Saltek Motorsports's tailgate molle rack instead.
I finally was able to knock the studs out:
  1. Screw the nuts to the end of the studs so they're flush with stud tip
  2. Use a 2-4lb hammer
  3. Wear ear protection (seriously)
  4. tap slightly hard for probably about 10 minutes straight each
Interestingly, the constant tapping at ~half strength worked WAY better than trying to smash the hell out of the studs.
Old Sep 10, 2024 | 08:18 AM
GrouseK9's Avatar
Well, I almost fell in love with it. In fact, I'll probably be a customer anyway because I love the wheel cradle. As a guy who's removed that rear tire WAY too many times alone, I could definitely go with it as an "aid". But at about 26:50 he had the great idea of turning it into a ladder. Then I had the thought: why don't I just find a way to put a base on the bottom of my Lucky8 Rhino ladder?? I think I'll explore that option first. And, it seems the Hi-lift bracket for a Yakima basket would fit the Lucky8/Rhino ladder just right! Bueno, now to order the cradle.
Old Sep 10, 2024 | 03:43 PM
Defendeth's Avatar
There are extra mounting points on the base of the Saltek Tailgate Rack that @Saltek Motorsports has mentioned will be a hosting point for future accessories. I'm hoping one option will include a wheel cradle. Because you're right... when you're changing the wheel by yourself, holy smokes do you want that additional support!
ponderosajack
Apr 8, 2024 11:00 AM
Caddo
Jul 29, 2023 07:50 AM
a9009
Aug 17, 2022 05:10 AM
PurpleRain
May 30, 2019 03:46 PM
RhinoRover
Nov 7, 2017 07:02 PM
