Spacers 30mm and original 22" wheels
Old Aug 12, 2021 | 03:14 AM
Babadook's Avatar
Default Spacers 30mm and original 22" wheels
Hello,
it's ok with 22" and 285/45/22 with the originals wheels and add 30mm spacers? No Lift
Or i'ts rubs?
thanks a lot
Old Aug 12, 2021 | 02:57 PM
Defendit..'s Avatar
Depending on your wheel design at the inside ( If there are open spaces between the lug holes)
You can have spacers in 20mm, 22mm., 25mm.
I will try to mount tomorrow 22mm.in front, 25mm. at the rear. ( on 18" satin dark grey 5094 wheels)
The studs on the Defender are 27 or 28mm.
Old Aug 18, 2021 | 05:04 AM
Defendit..'s Avatar
Put on the spacers 22.mm front, 25mm rear.
Stance clearly improved, handling & cornering also improved.
Looks factory ( as it should have been from the factory)
Old Aug 19, 2021 | 09:30 PM
Pseftis's Avatar
looks great.. anymore pics??
Old Aug 20, 2021 | 03:13 AM
Defendit..'s Avatar
Old Nov 13, 2021 | 07:34 AM
DPReef's Avatar
What specific spacers did you use brand/part? I have 22" rims with 285/45/R22 tires and want to add spacers w/o changing the lugs. would 30mm spacers be ok w/o any bolt/lug changes?
Old Nov 13, 2021 | 07:51 AM
_Allegedly's Avatar
How much does that change the load rating?
Old Nov 13, 2021 | 08:59 AM
Defendit..'s Avatar
The original lugs are 27 or 28 mm, so with a spacer from 25mm you have to shave off a few mm of the original lugs. Not a problem
with 30mm spacers there is no problem.
With my 18" 5094 there are open spaces between the lug holes at the backside of the rim, No problem with them for all sizes spacers.
Loadrating, I don't know. Should be the same.
I bought my spacers here: 20/22/25/30
https://www.tunershop.de/shop/h-r-sp...scovery-v.html
Old Nov 13, 2021 | 09:53 AM
_Allegedly's Avatar
I've always thought it was a really bad idea to add spacers purely for aesthetics. Reduced turning, extra roll and less effective suspension in hard turns, extra wear on suspension components and bearings, safety issues, unusual tire wear, more stress on the wheel itself, reduced load capacity...
I'm willing to accept that I'm wrong.
Old Dec 26, 2021 | 05:36 PM
RR2Dfndr's Avatar
Do you have any “click” from the wheels when you brake or accelerate after installing the spacers?
I just got Bora Spacers and installed them yesterday with the recommended 140Nm of torque. I notice this click when I’m parking (going reverse and forward)
