I don’t know what I did. I popped off the 12v cigarette plug and installed a new usb-c but it didn’t work. I reinstalled the 12v lighter plug and it doesn’t work anymore either. What did I do wrong?
Did I blow a fuse?
There are 2-3 places where fuse panels are. The most convenient is in the back cargo area behind the silver cover on the right side, which I think is where an air compressor might go if you had that option.
I just did cut the Green wire, isolated the original direction. Routed a new wire 12v from battery+ and connected that to the Green wire left on the socket. See last on the below diagram. Socket 12v Accessory Front
