What is this rattle? Rear Suspension Dampener? Will my rig be okay for another 1K Mi?
Old Jan 19, 2026 | 02:22 PM
  #51
Aberner's Avatar
did you say your rattle is back? How long did it stop before if started back up? Mine is currently at the dealer and just received a text that they think its fixed. fingers crossed when i pick it up in the morning that it has been. i will keep everyone posted.
Old Jan 20, 2026 | 02:01 PM
  #52
nashvegas's Avatar
Interesting that it was replaced 2x and persists. I would say, from having done it myself (the repair), something is amiss or not adding up. Replacing the shock with a good one / new one fixes the issue (I did it myself). The shock is super easy to diagnose and all you have to do is drive it around with the interior trim off. Noise is right there (see my video in another post). There’s no mystery in the diagnosis in other words.
So. Either they are not replacing the shock itself (the mount replacement does absolutely nothing)
Or they’ve incorrectly diagnosed.
If they replace the shock (which comes as an assembly with the new upper mount, pre-torqued in to proper spec) -- it would fix the issue. Maybe you have another loose component they just are missing and blaming the shock (again though, easy to pinpoint the shock as cause).
I’m with you all. My right rear is rattling for the last 500 miles and I’m annoyed I have to replace that one. boo,
Old Jan 20, 2026 | 09:03 PM
  #53
Aberner's Avatar
I’ve seen on some other forums that it could be
Rear air suspension control valve (solenoid) what are your thoughts?
Rodsrover
Range Rover L322 (3rd Gen)
Mar 22, 2021 11:04 PM
JOAT
Jun 15, 2020 07:42 AM
RA021226
Apr 27, 2018 01:46 PM
Redduc
Jul 10, 2015 08:25 PM
Firsty
Feb 22, 2008 08:00 AM
