04 DII Build Thread
Old Feb 13, 2017 | 02:22 PM
  #91
Mstudt's Avatar
Originally Posted by brolome
Were you able to retain the heated seats option? Not sure I caught that anywhere in the above post...
I was able to keep the heated seats. I was just a matter a fitting the electronics under the manual seats.
Old Feb 24, 2017 | 07:46 AM
  #92
Mstudt's Avatar
I recently came across a great deal on the TRED4x4 recovery boards, and picked up a set. I was a bit disappointed that Front Runner doesn't offer a TRED mount, and only offered a Maxtrax mount. The Maxtrax have different spacing than the TRED's so the mounts wouldn't work for me.
After searching, and not finding anything that would work I decided to build my own. These are made from 3/16"x2" flat steel, and bolt on the Front Runner slats. The two brackets have 1/2-13" threaded studs welded in place, and utilize the Hi-Lift locking handles.
Size:  144.6 KBName:  20170223_163059_zpsm0slzlfa.jpg
Old May 5, 2017 | 09:46 AM
  #93
Mstudt's Avatar
I've been away from this thread for a few weeks due to an engine install. With the new 4.6 installed, and running good. It's now time to get back to work here, and I'll have some updates after this weekend.
In the mean time here's a thread to my engine install. There's some good information in this thread, and hopefully others will find it useful.
Old May 9, 2017 | 10:18 AM
  #94
Mstudt's Avatar
Had a little forward progress this weekend. I was able to install our ARB compressor, and get the winch mounted up.
I decided to put the ARB CKMA12 compressor under the passenger seat. I decided to make small extension to come off the frame I made for the safe. I also added a fixed piece of air line hose to the compressor so I wouldn't have to reach under the seat trying to find the connection. The compressor sits nicely under the seat, and is powered through the BlueSea fuse box that's installed on the platform.
Installing the winch was a pit of a pain. I had to trim some of the grill support to clear the winch, and had to trim the grill some too.
Old May 12, 2017 | 03:31 PM
  #95
The Deputy's Avatar
Looks great. Were there any sensors for the SRS system in the seats? Some cars have sensors built into the seat frame, that if the seat rocks forward a certain degree or rips from the floor...it sets off the airbags.
Really like what you have done with this rover. Keep up the good work.
Brian.
Old May 15, 2017 | 06:48 AM
  #96
Mstudt's Avatar
Brian.
No sensors that I noticed. The only difference were fuses for the heated seats, and motors.
Old May 22, 2017 | 07:34 AM
  #97
Mstudt's Avatar
Over the weekend I was able to get quite a bit done. I swapped out the bad afn clutch, fan blade, and ac fan motor for good parts.
Clutch - 922790
Blade - 620-112
Motor - PM9116 (fan blade trimming required)
Sorry for some of the not so good pictures. I usually have my wife take pictures, but she was working on her own projects. On Sunday I knocked out our dual battery install, and it wasn't too bad. I was on the fences about installing a National Luna dual battery, and finally decided to do it. Since the plan in to live out of the Rover we needed to have some extra juice just in case.
I took the original box, and cut a little off the bottom to help fit the batteries.
Next I added a battery tie down that uses two of the mounting bolts. This is very simple, and wraps around the new tray, and both batteries to hold them in place.
While cleaning the garage I was able to find a nice sheet of aluminum that I used to make two single battery trays, and a corner piece. I used RTV to fix the corner piece to the battery box. Since it was open to the elements I decided to cover it.
Here's the finished product. I'm not to keen on the location, but there isn't much to work with under the hood.
I'll have to get a picture on the monitor mounted inside still, and I'll post that here later.
Old May 22, 2017 | 07:55 AM
  #98
FloridaRover's Avatar
I've been thinking about a dual battery setup but haven't dug into the design yet, did you use a kit or build all the components?
Old May 22, 2017 | 08:21 AM
  #99
Mstudt's Avatar
I went with the kit this time, and not sure if I'd do that again. At least not on the Rover since you don't need much due to how compact everything is. The kit gives you 20' of power, and 20' of ground wire. I only needed 2' of power, and 1' of ground to wire the system. If you plan on running addition inside the cab you can use the extra wire, but I already had that taken care of.
The kit was about $350-$400, but I can't remember. You can purchase the solenoid for $140, and the controller for $95. You'll need two fuse blocks, and various size lugs for the connections. I bet you could piece it together for about $250.
Old May 30, 2017 | 07:11 AM
  #100
Mstudt's Avatar
Over the long weekend I was able to get quite a bit more finished up, and I can finally say I'm in the home stretch. I don't have much left to do anymore, and that's a good thing.
Over the weekend I was able to power up everything on the inside of the Rover, and everything works like I hoped it would. I didn't get around to wiring the dash switches, and decided to go another route with them.
I ordered the switch pod below, and ordered new Carling switches to fit the pod.
