4.6 engine build
Old Mar 29, 2015 | 04:54 PM
  #101
dusty1's Avatar
yeah, then pull engine is best. honestly, i'd rather pull an engine than a tranny anyway.
Old Mar 29, 2015 | 06:45 PM
  #102
TOM R's Avatar
Trans was not that bad except drive shaft bolts
Old Mar 29, 2015 | 07:15 PM
  #103
arahim93's Avatar
Default 4.6 rebuild
I'm currently in the process of rebuilding the 4.6 out of my '03 Discovery, and am trying to locate the dowty washers that go on the side bolts. If you don't mind where did you purchase yours from, also how many are required? I was on roverparts.com and they say 19mmx9 washers and 16mmx2 are required. But I am confused as there are only 10 side bolts for the main caps. Sorry for all the questions, and hope you can help me.
Old Mar 29, 2015 | 08:18 PM
  #104
dusty1's Avatar
SEALING WASHER 19mm OD V-8 EFI, ERR3330 - Rovers North - Classic Land Rover Parts
or
Dowty Washer at www.rimmerbros.co.uk
.....they go on allen head end bolts too......so 10 required.
i would have easily reused mine if i had not already purchased new. they were hardly compressed and would have been fine to flip over and reuse
Old Mar 29, 2015 | 09:58 PM
  #105
TOM R's Avatar
What are those for?
Also are the main and rod bolts reusable on this engine?
Old Mar 29, 2015 | 11:42 PM
  #106
dusty1's Avatar
the dowty washers are to seal oil from escaping past the cross bolts going iinto the main caps.
both main and rod bolts are said to be tty and need to be replaced. i replaced them. there is numeric evidence that they are not all tty. my cap bolts were numbered as if they were standard grade bolts........rave says they are stretch.....many many reuse them both
Old Mar 30, 2015 | 04:51 PM
  #107
Shiftonthefly1's Avatar
Dusty what exhaust system are you planning to run? I saw you ask about headers in another thread. Cats or no cats?
Old Mar 30, 2015 | 05:48 PM
  #108
dusty1's Avatar
i am going to leave the cats. unless i can find out if those non foulers really work.
so it will be the long tube headers spliced into the originalish system
Old Mar 30, 2015 | 05:57 PM
  #109
TOM R's Avatar
dusty i know fooling the downstream on my 98 works
Old Mar 30, 2015 | 06:58 PM
  #110
dusty1's Avatar
Did you use non foulers or ??
