Clancy '97 D1
Old Dec 17, 2015 | 06:17 AM
  #101
Detoured Discovey's Avatar
Looks like you're going to have a white Christmas!!
Old Dec 17, 2015 | 06:39 AM
  #102
fishEH's Avatar
You can get corrected front radius arms which are also a tad longer. You can space the rear trailing arms back usinglarge washers. Keep in mind your driveline angles when doing so.
That said, you ahould not need to push your axleals. There's no tire you can fit on a 2" lift that necessitates pushing the axles.
A camel cut is all you need.
Originally Posted by Detoured Discovey
Lift looks good Jason!
What's the fix to push the axles out again after lifting?
Other markets have adjustable control arms, I have yet to look into this for our trucks so this is a sort of short cut question. Any thoughts out there?
Old Dec 17, 2015 | 08:01 AM
  #103
Trail-Tailor's Avatar
Former Sponsor
I don't think the axles are an issue until 3" or larger lift and 35" plus tires. My intended ~32"ish tires will be just fine.
J
Old Dec 17, 2015 | 08:04 AM
  #104
Former Sponsor
We had about 8" dumped on us the other night. Seems like it is going to be a wet and snowy winter. Been awhile, usually cold and icy here.
J
Old Dec 17, 2015 | 01:59 PM
  #105
fishEH's Avatar
Exactly. And you really can't push the rear axle back too far until you run into clearance issues where the rear floor meets the wheel arches. Only 3 ways to fix that.
1) Severely limit uptravel
2) Jack your truck waaaay up, like 5" springs
3) Cut and reweld the floor/arch
J
Old Dec 17, 2015 | 02:21 PM
  #106
I would just like to get my wheels back in the center of the wells when the time comes......the pinched and puckered look bother's me.
Old Dec 19, 2015 | 08:45 AM
  #107
Former Sponsor
Going to bring Clancy back into the shop this week.
Need to finish bleeding the brakes. I must have really pulled some air into the system when changing that one caliper. I have to stand on the pedal now to get him to stop. Hopefully it is just a simple ring a round the rosy a few times and back to normal. RR,LR, RF and LF is my pattern.
Then onto the fun stuff...
J
Old Dec 21, 2015 | 03:58 PM
  #108
Former Sponsor
LO-PRO rack is mostly complete and tacked out. Still need to get the crossbars, tie downs and light tabs on.
Tomorrow I will start the EXPO/ RTT rack
Jason
Attached Thumbnails Clancy '97 D1-p1110168.jpg   Clancy '97 D1-p1110169.jpg   Clancy '97 D1-p1110170.jpg   Clancy '97 D1-p1110172.jpg   Clancy '97 D1-p1110174.jpg
Old Dec 22, 2015 | 05:54 AM
  #109
drowssap's Avatar
that looks great, it really does.
I have question though shouldn't the weight be carried by the A B C D pillars?
in other words should the front and rear brackets be pushed out to the ends of the rack, rather than setting the weight over window openings? the weight would be transferred to the A & D pillars. just an idea
great work
Old Dec 22, 2015 | 09:04 AM
  #110
Former Sponsor
great work
Thanks for the kind words Drow. I will be cleaning up the front of the rack today.
In a perfect world the load should be placed as close to, on/over the pillars as we are taught/told.
The A-pillar is the only one that it is really hard to get a mount close to.
Most companies build so the mount feet are equal in distance from one another to be more load bearing and that their deflection calculations are similar across the length of the rack. This also makes them look more proportionate on the rack, but not as functional for a true load bearing design, unless there are several of them.. 8-12 mounts, IMO.
After all the racks I've built over the years and actually field tested.... The gutter rail is what takes the true abuse of the system, not the pillars. The best thing to do is have a mount with a wide foot (3"-6") to even further distribute the load. Less psi per running load width is what we are after.
I'd honestly be comfortable loading this rack up (RTT and 200-300# gear) with 6 mounts and none being placed over any of the pillars and hitting the trails, etc..
Jason
