my 98 disco1
Old Oct 2, 2013 | 08:55 AM
  #151
binvanna's Avatar
ok, I read in the other thread, "the balljoint did not appear bad but dad talked me into replacing it since so cheap and no way to grease plus a destroyed boot." I think I'll keep mine at least through the winter.
Old Oct 2, 2013 | 06:21 PM
  #152
TOM R's Avatar
I could not figure a way to test on vehicle, it was not clunking, still greased, off vehicle it moved freely almost loose, but no play, moving it aroung we found a tight spot so for price and apart we just did it, the hf plates work fine for me press is 10 years old
We have used sockets but I recommend getting their ball joint press tool and the extra adapter set for that tool, they work great on the press
It did take all 20 tons to do the upper A arm and ball joint I was close to paying for press out
Old Oct 17, 2013 | 03:48 PM
  #153
TOM R's Avatar
Pics of the exhaust we made up
Buy a muffler with center inlet offset outlet and a piece of straight pipe to fit the inlet think we used 2.5"
Cut the flange off the OEM muffler weld onto your straight pipe
lay that and the new muffler side by side cut down the pipe to make the assembled pipe and muffler length same as the old muffler BE SURE THE FLANGE IS CLOCKED CORRECTLY BEFORE ANY PERMANENT ATTATCHING
We clamped this in case the pipe outlasts the muffler and I need to do it again this is the second time I rebuilt this exhaust since owning the Rover 4/5 years now
We bought a new over axle pipe amazon or ebay cheapest, 45* , straight pipe, universal turn down ( this goes in place of the rear resonator)
With muffler mounted install over the rear pipe making sure it is positioned where the upper A and axle will not hit we had a jackstand under the muffler and tacked on the over axle pipe
Then assemble the remaining pipes and attach the 45* to the over axle pipe and make length adjustments as needed so the tailpipe comes out in the proper location
Lastly remove and weld up then final assemble on vehicle, at this point you will need to weld a hanger at the front and rear of the muffler
We found the over axle pipe to be an odd size tubing, and the 45* is needed cause the over the axle is incomplete the last bend is part of the rear resonator
Wish I had pics from the process
  #154
TOM R's Avatar
Old Oct 17, 2013 | 03:49 PM
  #155
TOM R's Avatar
Old Oct 31, 2013 | 04:07 PM
  #156
TOM R's Avatar
Installed some used rear lowered shock mounts, how do I get the upper urothane bushings in? They are huge tried the press but they will not go in far enough to start the nut reused rubber uppers for now
Old Oct 31, 2013 | 04:10 PM
  #157
TOM R's Avatar
Old Oct 31, 2013 | 04:12 PM
  #158
TOM R's Avatar
Old Oct 31, 2013 | 04:25 PM
  #159
TOM R's Avatar
Next question, I have fronts to do, are they left right? They do not look clocked the same they were gray
Old Nov 2, 2013 | 06:53 PM
  #160
TOM R's Avatar
Got the fronts on today, I guessed the flat spot on base faces the wheel but I have no idea if they are on the correct sides as they are clocked different
