my 98 disco1
Old Apr 14, 2014 | 03:07 PM
  #221
TOM R's Avatar
Looks cool though
Fish I cut my Saudi grill boo hoo
Old Apr 14, 2014 | 03:41 PM
  #222
TOM R's Avatar
Suggestions on the skid plate?
Thinking 1/4" aluminum, while I like diamondplate it is hard to clean and not smooth for sliding over things
Thoughts?
Old Apr 14, 2014 | 04:49 PM
  #223
CUpgt's Avatar
I used roughly 1/4" aluminum with dimple die holes in it. Looked sweet!
Old Apr 14, 2014 | 05:39 PM
  #224
TOM R's Avatar
Dimple die? You must be a metal worker
Old Apr 14, 2014 | 06:06 PM
  #225
TOM R's Avatar
More questions
What is the basket floor I have seen mentioned in the past?
What are some accessories to mount that I can make mounts? Jack is on rear floor not really looking to put that heavy thing 6' in the air
Old Apr 14, 2014 | 06:11 PM
  #226
wrongway1's Avatar
Okay then, for me thered be no benefit other than aesthetics. Thanks for the input.
Old Apr 14, 2014 | 10:44 PM
  #227
fishEH's Avatar
The flooring is FarmTek. PolyMax Poultry/Kennel Flooring - FarmTek
I saw you cut the grill!!! Since its cut you may as well move the winch even farther back. I loosened the cooler and move it back a touch for a little extra clearance.
I'd go with aluminum diamond plate or just flat. I have a diamond plate skid(more of a bumper finisher really) and it slides fine. I wouldn't bother with a really large skid, just upgrade your steering rods and you'll be ok. Maybe have it like this only.
I'd even consider less of a skid than what I drew. Im a fan of more clearance/better approach angle.
Old Apr 14, 2014 | 10:49 PM
  #228
fishEH's Avatar
And if I were building a bumper from scratch I'd make it to fit an 8274!
Old Apr 15, 2014 | 12:23 AM
  #229
TOM R's Avatar
I think the winch plate is back as far as we could with the cooler, winch solenoid us above that cooler
The skid will actually start bottom of winch plate matching the angle on the gussets, then bends for that increased angle you see, we were not sure how low to hang it so went for below pit man arm??
What's 8274?
The gussets are made from 1/4" channel I had made and run the inside of frame both sides to the cross member, so far it is lighter then the stock bumper and brush bar, nose is setting up
Old Apr 15, 2014 | 01:50 AM
  #230
CUpgt's Avatar
Warn 8274. Probably one of the best winches ever made
