my 98 disco1
Old Apr 27, 2014 | 07:33 PM
  #241
TOM R's Avatar
PAINT THREAD https://landroverforums.com/forum/di...y-paint-66697/
Decal thread. https://landroverforums.com/forum/di...-decals-66841/
Old May 6, 2014 | 08:53 PM
  #242
TOM R's Avatar
Rear main seal thread
https://landroverforums.com/forum/di...al-leak-66893/
Trans leaks
https://landroverforums.com/forum/di...97/#post462842
Old May 13, 2014 | 08:33 AM
  #243
TOM R's Avatar
In an attempt to keep moving forward on all aspects between working and rain here is the roof rack cleaned primed and sprayed with rustolium bed liner, the rear clam was free from the trash and just picked up the pelican case for a good price at the Aberdeen military show last weekend, these should yield plenty of space for camping gear
Old May 23, 2014 | 06:56 PM
  #244
TOM R's Avatar
Stuck ignition thread
https://landroverforums.com/forum/di...le-tone-67178/
Old Jun 5, 2014 | 08:37 PM
  #245
TOM R's Avatar
Just installed 3rd disc changer I need ideas where to move it off the floor
We go wheeling it gets wet poof let the smoke out
Old Jun 8, 2014 | 05:41 PM
  #246
TOM R's Avatar
Replaced this bad swivel big dark spot is heavy pitted
Actually got lucky pulled this whole assembly off another 98 in u pull last week so I installed in mine as an assembly makes it super fast that way, and this has a replacement caliper, mine old one was dragging
Think total for that assembly at u pull $50? Axle,knuckle, swivel, rotor, caliper, line, good pads, abs sensor
Without u pull I could not afford this vehicle
Old Jun 8, 2014 | 08:27 PM
  #247
ihscouts's Avatar
Yes you would, you'd work on others and make cash and parts.......
Old Jun 25, 2014 | 05:38 PM
  #248
TOM R's Avatar
Originally Posted by CUpgt
A ton of guys run skid plates so it may be a non issue. This is my current setup.
My old tube bumper had a skid but it barely came below the frame rails. You will have a good bit more protection on yours.
hope to get back on this soon, are the sides of that made from 3/16" ?
Old Jun 26, 2014 | 01:11 AM
  #249
CUpgt's Avatar
I'll double check but I'm pretty sure the whole bumper is 3/16 and the winch plate and frame mounts are 1/4"
Old Jun 26, 2014 | 06:08 AM
  #250
TOM R's Avatar
thanks thats what I figured trying to save a little weight where i can everything we did so far is 1/4"
