New Life for '98 Discovery 1 "Project Pig"
Well, i have a new fuel pump, but still not running!
I have a couple more things to check i guess, but as of now, I am still not getting fuel pressure at the rail.
So, next I guess I need to pull a plug and see if I am getting spark to determine if its my Crank Position Sensor.
Another thing that someone might be able to shed some light on is the actual cranking process. For example, when I turn the key to position 1, everything lights up, and when i go to position 2 to turn over the motor, there is a hesitation before it actually starts to crank over. Its not consistant, but there is a lag that wasnt there before. Sometime even holding in position 2 to start wont do anything, and then when i cycle the key, i will crank after a short lag.
Any thoughts?
Any thoughts?
Hi, it looks like you have some great plans for your disco, but kinda looks like you are no longer updating your build. I am also trying to pump new life into a neglected disco 1. I really like your drawings of your front bumper. I’d love to build a similar front bumper. Myself and two of my friends all have disco 1 that we are building. Did you ever finish the design? Did you build it? Any pictures? Would you mind sharing your cut plans? Thank you for your time.
Corrigan
Apr 26, 2013 02:38 PM
