Operation Magpie.
Old Jun 7, 2018 | 08:01 AM
  #271
Saturnine's Avatar
I bought an UG and OBD2 scanner months before I bought this truck
Old Jun 7, 2018 | 08:11 AM
  #272
Sixpack577's Avatar
I have an UG...yet to use it in my D2...because it doesn't run, lol. But, my Dad has one in his truck, and it's s really cool gadget, it does alot.
Old Jun 7, 2018 | 08:15 AM
  #273
Saturnine's Avatar
I have to unplug mine and plug it back in maybe once a week, I think at some point I’ll check out the wiring to the port to see if there is anything wonky.
Was it DOA?
Old Jun 7, 2018 | 08:39 AM
  #274
Sixpack577's Avatar
My D2 doa?
No, I actually drove it home when I bought it, not much since, lol.
Old Jun 7, 2018 | 07:15 PM
  #275
The good Rover's always make it home to die
Old Jun 7, 2018 | 08:03 PM
  #276
Saturnine's Avatar
The UG not your D2 haha
Originally Posted by Sixpack577
My D2 doa?
Old Jun 7, 2018 | 08:36 PM
  #277
Sixpack577's Avatar
I've never tried my UG, just used the one in my Dad's truck.
I took my D2 battery out before buying the UG, the battery since died and won't recharge. I'm going to wait until my engine is back in and ready to start before buying a new battery, as I don't have alot of time to work on it...I don't want to crank it on a new 6 month old battery, lol.
I hope my UG works! I'm going to use my Nanocom for a few days, before using the UG full time.
Old Jun 7, 2018 | 08:51 PM
  #278
Saturnine's Avatar
BTW, just adjusted the theottle cable and everything seems to be normal
Idle rpm should be upper 600s, right?
Originally Posted by Best4x4
Remove the throttle body cable and Cruise Control cable then manually move the TB plate by hand. Does it stick? If it does simply remove the TB from the D2, remove the 3 screws holding the TB plate into position and then it will slide out from the TB. Take a scotchbrite pad to the outside edge until it's nice and smooth. Then you can use the scotchbrite pad on the TB itself inside. Then re-install and it should be silky smooth. If it sticks when only connected to the cables one of them is binding.
Old Jun 7, 2018 | 08:56 PM
  #279
Disco_Dion17's Avatar
That sounds about right. 650-ish is my normal idle.
Old Jun 7, 2018 | 09:45 PM
  #280
Saturnine's Avatar
Aye, thanks for that Dion!
Well, tomorrow is the day. DMV opens at 8am -- gotta get a temp tag, drive to get smogged and then back to DMV to get plates. I'm really hoping i don't have any issues with the cats but i guess i'll find out tomorrow
How are these trucks generally for getting smog? Is it like they either pass with flying colors or not at all with no real variance in between? Or..?
