Picked up another truck
Old Feb 3, 2019 | 07:03 PM
  #71
Not sure if l'm seeing it correctly (first picture of header), but is your ground wire bolted to the exhaust/header pipe? If it is, this is not a good location. If the connection terminal is soldered, the heat will melt the solder and you will lose your ground connection.
Brian.
Got those ground cables relocated as well.
Old Feb 3, 2019 | 09:17 PM
  #72
ihscouts's Avatar
Un-bubba'd. That should make a difference in the long run. Watcha gonna do with all those spare washas?
Old Feb 4, 2019 | 10:07 AM
  #73
Put them in the nuts and bolts bin I was running low on 3/8 washers
AtlasK
29
Dec 30, 2017 10:18 AM
RedneckHippy
Oct 14, 2017 06:13 PM
audiS4S6
Apr 18, 2010 11:02 PM
Spike555
ROAMING WITH FRIENDS
Jun 27, 2009 10:29 AM
Brad S1
Jul 2, 2006 11:05 AM
