Defender Talk about the Land Rover Defender within.
Injector seals woes...HELP!
Old Mar 19, 2014 | 08:44 AM
Raider TD5's Avatar
Default Injector seals woes...HELP!
I am doing the injector washers and O rings job on my car but I am kind of stuck now.
The new washers are genuine LR part but they wouldn't go past the mid point on the injector nozzles. Am I doing anything wrong? I have cleaned the tip using fine sand paper and there's no carbon left on the tips but that's not helping. I tried forcing them a little but to no joy.
Don't want to damage any thing since nothing is available here.... got these from Dubai as well.
Do I place the washers in the head first then install injector and use the clamp to seat them in place by tightening the bolt? Is that the correct way? Would that damage anything?
Also, I washed the injectors with petrol... is that okay??
Please help?!
Attached Thumbnails Injector seals woes...HELP!-1-.jpg   Injector seals woes...HELP!-2-.jpg   Injector seals woes...HELP!-3-.jpg   Injector seals woes...HELP!-4-.jpg   Injector seals woes...HELP!-5-.jpg
Old Mar 19, 2014 | 08:48 AM
Raider TD5's Avatar
Any I have these questions too...
How do I clean the whole loom.. from the injector socket to the red socket?
How do clean the MAP sensor.. what and how to use?
My glow plug sockets were very brittle and I broke all 4 of them while removing them.... whats the fix?
Old Mar 19, 2014 | 01:42 PM
tuercas viejas's Avatar
If you have just broken the plastic wrap around cover, then try a Dodge Sprinter glow plug cover from Dodge source or MB dealer.
About $5 a pop.
If the inside end terminal is compromised its a soldering job; again ends are available from MB source refer to2002 to 2006 TIN 903 Sprinter 2.7 5 cylinder diesel.
T/V
Old Mar 20, 2014 | 08:03 AM
Raider TD5's Avatar
About $5 a pop.
T/V
Thanks.. will check that out.
Old Mar 20, 2014 | 08:04 AM
Raider TD5's Avatar
Any idea about the seals... anyone??
Old Mar 20, 2014 | 09:43 PM
Amigo,
The washer must be seated on the injector, standard practice.
To seat it try some "GENTLE" pressure uisng a tube like tool, suggest a thin socket and go easy it should slide down onto the seat.
Make sure to seat in the injector tube is absolutely clean and NO carbon. I use rifle barrel cleaning brushed for that job. If the injector doesn't seat due to dirt on the seat it will aerate the fuel chamber/rail gallery and give you rough running or no start conditions.
Do not be tempted to force the injector down with the retention bolt.
Are you replacing the sealing O ring its recommended. Always use a lube to slide the injector into the tube. I use engine assembly grease but vaseline is a good substitute.
You can clean the MAF sensor with well MAF sensor cleaner--like this.
https://www.google.com/#q=maf+sensor+cleaner
Now that harness!
Notorious for degrading I usually throw it away if its seriously deteriorated .
If you want to re-use it you will need to ohm it out checking each individual wire connection for continuity, no cross connections and no short downs and good socket retention . This can be a chore. Expect to see next to no resistance.
Hope that helps you.
Amistades
T/V
Old Mar 21, 2014 | 10:41 AM
Raider TD5's Avatar
Okay. I tapped the washers into place with a 8mm socket, it did leave a mark though but hopefully its all good!
Yes did replace the O rings too.
Thanks for the help Tuercas!
Old Mar 21, 2014 | 10:36 PM
Raider TD5's Avatar
Where do these parts go?
03 discovery 2
Mar 22, 2017 08:23 AM
Andy2Rover
Aug 22, 2015 02:48 PM
Thomas Lane
Feb 24, 2015 09:26 PM
humroot
Nov 30, 2014 12:09 PM
dc10freighter
Oct 30, 2009 04:34 PM
