Fuel Injector Woes
Old Oct 29, 2009 | 10:07 PM
dc10freighter's Avatar
Default Fuel Injector Woes
Hey Guys I just finished my head gaskets. While I had everything apart I put new wires, plugs, hoses, serpentine belt, water pump on. I was trying to make the car as reliable and take care of as much preventative stuff as I could.
While I had it torn down I took out the injectors and had them cleaned and checked. We have never had any problems with the car other than the head gaskets but the shop told me the injectors were leaking down pressure.
I asked if the volume and the spray patterns were good, and he said they were so I put them on the car.
Now whenever we start the car its a little hard to start, I presume from the fuel pressure needing to build. If we just shut it down for 10 minutes or so it starts right up, it is hard to start if it sits for more than a half hour or so.
I guess I need to bite the bullet and put new injectors on, what do you all think.
Thanks
Old Oct 29, 2009 | 10:30 PM
NiteTrain's Avatar
before you start replacing injectors hook up a fuel pressure gauge and see how much psi you are getting
Old Oct 30, 2009 | 09:48 AM
antichrist's Avatar
If you do replace them, I haven't seen them cheaper than at Summit.
http://www.summitracing.com/parts/FMS-M-9593-C302
Old Oct 30, 2009 | 04:34 PM
Sounds like your fuel pump is not holding pressure.
I have never heard of a injector not holding pressure unless it was clogged and leaking, but then it would be hard to start from to much gas in the cylinders.
Have the fuel pump checked out, I am betting that is the problem.
Raider TD5
Defender
Mar 21, 2014 10:36 PM
tornado_735
Mar 31, 2009 09:33 PM
lennie5936
May 16, 2008 06:31 PM
lennie5936
May 7, 2008 11:45 AM
DeepBlueWater
Oct 15, 2007 07:38 PM
