1994 1995 NAS DI RRC Alarm Bypass
Old Mar 31, 2016 | 02:46 AM
  #21
ihscouts's Avatar
Central locking is about all the door locks functioning off the drivers lock actuator. Nothing to do with the center differential (transfer case) locking of front and rear axles together.
Old Apr 6, 2016 | 07:39 PM
  #22
Roverfanatic's Avatar
That's funny, although the work done recently on my car might make that actually happen
I was in Dallas last month and found a 95 disco at a salvage yard that was in great shape. Among a ton of other parts I pulled off it, I was able to get the driver door lock actuator and the green alarm module that is an exact match for my truck. (They often have a different module)
My question is, the two white and orange wires that go to the alarm module, can they be inverted or switched? Reason for the question is I am not sure if I am going to be able to tell by just looking at them which is which? Sort of hoping a just a open/closed circuit thing, so it won't matter.
Old Sep 26, 2016 | 12:38 PM
  #23
Bford's Avatar
Will this be the same for 94 3.9l standard. I have replaced everything in it and no power to the inertia or fuel pump relay. Power to the fuse but not anything else. Was running great and than nothing. Replaced all fuses and relays. Only thing is can come up with next is the alarm keeping it from starting. No power to the pump or anything. Please help!
Old Dec 13, 2017 | 10:05 AM
  #24
lrnoob's Avatar
Are there any photos/videos/write ups on exactly how to do this bypass? I am a complete electrical newbie, so this is like a different language to me. But, I'm not able to start my Disco, so I'd like to give it a try.
Old Dec 15, 2017 | 05:57 AM
  #25
I followed Paul Grant's instructions and it was not hard just remember your are going to be tapping into a ground wire that is already there, so make sure you make a good connection. The other thing I wish I would have done before cutting the wires is used me label maker so I would know which one was which. I found a replacement had had to guess which connector to use. Not even sure it matters but why take the chance just label so you know which one goes back to the wire you cut.
IHScouts is also correct, this has nothing to do with central locking. In my case, it was a bad master actuator on the driver door side. Just go slow and ask questions if you get stuck.
Sorry, it took so long to answer but I was in the hospital getting stabbed over and over with needles. I tried to answer on my Android but as with all these forum sights, the password protection is like there guarding Fort Knox. No offense to the admin....there all like that. Good Luck Tex
Old Jul 3, 2020 | 02:07 AM
  #26
BierNut's Avatar
This alarm bypass to start mentions "neutral switch", can this alarm bypass to start be applied to a 95 D1 with a manual 5 speed transmission?.......~~=o&o>.......
Old Jul 3, 2020 | 12:22 PM
  #27
You might want to message Paul Grant directly about this but I am pretty sure you will have no problem doing this on a standard.
Old Aug 28, 2020 | 11:08 AM
  #28
LipLounge's Avatar
I've heard about this issue a lot on many different forums and I'm thankful to see the post focus on 1994 and 1995. What does RRC stand for by the way? My fuel pump kicks on and I have 34psi at the fuel rail. Engine cranks but won't start. Does this issue apply to my situation? Or does the alarm issue cut power to fuel pump too? Therefore I would have a different problem. I get fuel but no spark at the plugs. New ignition coil with good spark. I'm about to replace the distributor and hoping that does the trick. Are there any other auxiliary parts in the ignition system that I should consider?
I hope I'm not getting too far off topic.
Thanks in advance.
Old Mar 19, 2022 | 08:05 PM
  #29
94Disco1's Avatar
Has anyone experienced the "flasher relay" clicking constantly AFTER doing this bypass without the hazards button being depressed?
Old May 13, 2025 | 10:24 AM
  #30
jimvw57's Avatar
RRC stands for Range Rover Classic
Babsido
Jan 30, 2015 04:41 AM
Mapolo
Defender
Jul 3, 2012 05:23 AM
nahtanoj
Mar 26, 2012 11:34 PM
sbuige
Feb 24, 2008 08:57 PM
crownaviation
Sep 7, 2007 02:37 PM
