1996 discovery
Old Mar 19, 2012 | 11:28 AM
fire771087's Avatar
4wd High
Default 1996 discovery
Went to have oil changed on Saturday followed owners manual when it was done started engine to look for leaks and the engine started missing any ideas Also the engine when hot will just stall and will not start until you jump start it any ideas
Old Mar 19, 2012 | 03:01 PM
Missing is usually plugs and wires related. Stalling out when hot, then won't re-crank untill cooled off (it takes tiome to arrange a jump) - may be crank position sensor. This controls spark, next time it does this check for spark; you can also pour cold water on the CKP sensor to speed cool down - drivers side rear of engine.
Old Mar 19, 2012 | 09:18 PM
Need a lot more information, mileage, when was it last tuned along with plug wires and fault code numbers.
pzwerner
Mar 25, 2007 10:01 PM
newb
Appearance & Camping Set Ups
Mar 11, 2006 06:01 AM
tjsteph
Feb 9, 2006 10:43 PM
bboat567
Jan 15, 2006 11:15 PM
mauemiliani
Dec 6, 2005 05:04 PM
