1998 Disco I Valley Pan Gasket Replacement
Old Dec 9, 2012 | 10:02 AM
Beamer1's Avatar
Default 1998 Disco I Valley Pan Gasket Replacement
Hi Folks,
Finishing up a head hasket replacement job (among other items). When installing the valley pan gasket, does the rubber end gaskets on the engine with a bit of silicone go on the engine first, then the valley pan gasket sets on top of that, then the metal ends with bolts go over that? Sorry if its vague. The diagram (#22) appears to show two of the metal ends only. After that, I just carefully set the intake manifold over that and line everything up? I've had non-rover buds tell me to put a bit of silicone on the intake too...Appreciate any guidance...
Thanks
Scott
File Type: pdf
Old Dec 9, 2012 | 11:17 AM
Bkreutz's Avatar
Originally Posted by Beamer1
Hi Folks,
Thanks
Scott
That picture is kinda misleading, you put the rubber seals on the block first (I use ultra black gasket maker on the rubber, but there are multiple opinions on that), then the "paper" intake gasket, then the metal pieces on the top.
Old Dec 9, 2012 | 12:09 PM
Beamer1's Avatar
A thousands thanks!!
Old Dec 9, 2012 | 05:31 PM
jfall's Avatar
LIttle rubber gaskets on first.
Put a little permatex non-hardening on the lip of the engine block first.
And, put dabs of permatex in the corners where the heads meeting block.
Put on the rubber piece on each end.
Then the valley gasket.
Then the metal retainers with the bolt.
You can see pictures of this at
1997 Land Rover replace catalytic converter and head gaskets
Look for the flickr pictures.
Old Dec 10, 2012 | 07:35 AM
Beamer1's Avatar
jfall, thanks. I actually read and reread your procedure to perform the work. The intake went on and I followed the modified Rover torque procedure. Put the valve covers on and then lost my 12 point 8mm...Have burned at least an hour...Still haven't found...Is there a black hole in Rover engine compartments?
Old Dec 10, 2012 | 07:52 AM
keep looking, don't want to start another "tick"......
Old Dec 10, 2012 | 09:42 AM
jfall's Avatar
I bet your socket is under the intake manifold on top of the valley gasket.
or hit the floor and rolled
or sitting on the frame
you need a bright light to look for it
Old Dec 11, 2012 | 07:37 AM
Beamer1's Avatar
I heard the socket hit once, then nothing. Usually you will hear it hit once or twice then the floor. Looked for an hour on Sunday and Monday. Behind starter, valley gasket, tranny, front axle, suspension, wheel well area...tried shaking the vehicle. Hmmmn
cmthompson
Dec 15, 2014 05:11 PM
jpmiller
Sep 26, 2012 06:32 AM
bgtroop
Jul 8, 2012 04:42 AM
chad420
Oct 24, 2009 02:51 PM
JimScream
Jan 6, 2009 02:01 PM
