1998 Disco no start diagnosis help
Old Apr 8, 2019 | 10:14 PM
huggi's Avatar
Default 1998 Disco no start diagnosis help
Hello all, so I bought a cheap trail rig rutland red 1998 discovery. Towed it home, trying to diagnose the no start, I've figured out the fuel pump isn't getting any voltage. I put 12V to the fuel pump and it kicked on. Looked at the fuel pump relay behind the washer bottle, the connections looked clean. Checked the inertia switch. I looked at the relays in the passenger footwell, which one controls the fuel pump? What do you guys recommend as a next step buying a new fuel pump relay? Is there a way to test the fuel pump relay?
I've attached a few pics
Thanks
Old Apr 8, 2019 | 11:05 PM
Crunkgringo's Avatar
Did you test power at the fuse? Wouldn't that be a way to test the relay? It is under the hood in the box just behind the battery.
Austin Busby
Dec 20, 2018 05:12 PM
Travelor
Sep 24, 2015 06:11 PM
JPSpen
Oct 2, 2012 10:39 AM
taylorhertz123
Jan 4, 2009 09:06 AM
CraigR
Jun 28, 2006 02:26 AM
