2 inch lift vs shock relocation
Old Nov 11, 2016 | 02:46 AM
El Duce's Avatar
Default 2 inch lift vs shock relocation
Hey everyone, I was wondering what the differences would be between a truck that has springs and shocks two inches longer, compared to a rover with the standard height springs but 2 inch taller shock towers and rear shock mounts? How would the up and down travel be changed? Thanks in advance
Old Nov 11, 2016 | 09:47 PM
ihscouts's Avatar
Cost.
The first one increases wheel travel the second is for looks because it serves no other purpose over stock.
Old Nov 12, 2016 | 11:32 AM
TOM R's Avatar
I have a 2" lift and 2" lowered upper shock mounts/towers, allows more articulation with stock shocks, my springs dislocate
Old Nov 12, 2016 | 12:48 PM
fishEH's Avatar
Raising your upper shock mounts on stock springs makes no sense.
The stock shocks on stock springs have plenty of uptravel for stock tires. Raising the upper shock mounts with stock springs is going to put your tires way up into your wheel wells(sheetmetal contact) and will reduce your drop.
2" lift springs with 2" longer shocks will retain stock travel amounts while allowing for larger tires.
Joebern
Jun 21, 2011 05:09 PM
avking
Jan 23, 2009 08:27 PM
DYNAMITE DISCO
May 12, 2008 08:14 PM
morfa
Aug 27, 2006 01:22 PM
