94 Stalled in line at the drive through and wont start.
To be quick-
Sitting in line at the drive through. Cool evening, truck running fine. Stalls. No noise before hand or low idle. No nothin. The engine just stopped running. The Oil, Battery, and ABS lights came on and there was no break in electrical power as the radio kept running fine. Starter is cranking. I can hear the fuel pump relay and the pump itself initiate when I turn the engine on. Pressure is in the fuel line as well. I dont hear anything unusual when I try and crank it, it just doesnt start. Any idea's on things I should try?
Update? I'm curious about how this turned out because I had a similar
situation happen with my 95 D1. I never got any dummy lights on but it
started running rough while driving. I made it to my parents house
thankfully but I could only get it started/idled a couple of times after really
cranking it a while. But now I can't get it to start. It feels like it wants to
sometime but doesn't start. I checked for spark(inline spark plug tester)
and she was lighting up. I replaced the fuel filter. Fuel pump is humming for
a bit when I get the key in the 2nd position. I have not checked for fuel
pressure yet. I had trouble finding the schraeder valve for some reason(it
was dark and in hurry).
Suggestions from there?
Thanks,
Kurt
Thanks,
Kurt
