94 Stalled in line at the drive through and wont start.
Old Nov 7, 2013 | 11:09 PM
wabuson's Avatar
Default 94 Stalled in line at the drive through and wont start.
To be quick-
Sitting in line at the drive through. Cool evening, truck running fine. Stalls. No noise before hand or low idle. No nothin. The engine just stopped running. The Oil, Battery, and ABS lights came on and there was no break in electrical power as the radio kept running fine. Starter is cranking. I can hear the fuel pump relay and the pump itself initiate when I turn the engine on. Pressure is in the fuel line as well. I dont hear anything unusual when I try and crank it, it just doesnt start. Any idea's on things I should try?
Old Nov 8, 2013 | 09:25 AM
Racer X's Avatar
Do you have spark?
Old Nov 8, 2013 | 12:56 PM
wabuson's Avatar
Originally Posted by Racer X
Do you have spark?
yeah, albeit a little week. all the voltage readings from the ignition coil are right.
Old Nov 21, 2013 | 06:25 PM
MAN "O" WAR's Avatar
Update? I'm curious about how this turned out because I had a similar
situation happen with my 95 D1. I never got any dummy lights on but it
started running rough while driving. I made it to my parents house
thankfully but I could only get it started/idled a couple of times after really
cranking it a while. But now I can't get it to start. It feels like it wants to
sometime but doesn't start. I checked for spark(inline spark plug tester)
and she was lighting up. I replaced the fuel filter. Fuel pump is humming for
a bit when I get the key in the 2nd position. I have not checked for fuel
pressure yet. I had trouble finding the schraeder valve for some reason(it
was dark and in hurry).
Suggestions from there?
Thanks,
Kurt
kasperjd4
Aug 27, 2013 04:56 PM
newworld
Nov 28, 2011 12:00 PM
hampshier32000
Feb 8, 2011 09:45 PM
froggyj44
Mar 19, 2010 08:19 PM
mattkon
Feb 24, 2009 11:06 AM
