95 disco d1 dies after starting
Remove the cargo bay carpet and padding and remove the cover over the fuel pump, now see if you can hear it when turning the key. Don't start it just turn the key to pos II to start the pump.
If you still don't hear the pump come on check fuses - fuse F3 10A in satellite fuse box 1, fuse F6 15A in engine bay fuse box, fuse F7 20A is also in the engine bay and it's the whole enchillada.
Also while putzing around under the hood press the top on the Inertia Fuel Shutoff switch to reset it. It's mounted on the firewall inboard of the washer fluid bottle.
RichardLester
08-24-2011 08:37 PM
